ZWO cameras settings
5 replies to this topic
#1 poofer
poofer
Posted 13 December 2019 - 07:38 PM
I use APT for imaging and PHD 2.6 for guiding. Is it wise to use Ascom camera 1 for APT and in PHD use Ascom camera 2? I see in APT it allows ZWO native driver to connect to my ASI224 Pro. Also Sharpcap has Ascom driver for ZWO or the ZWO driver to select. What is most stable? Ascom driver or ZWO's native driver? Thanks Pat
#2 DrGomer
DrGomer
Posted 13 December 2019 - 07:41 PM
I use ascom since the native one doesn't work with the tec (asi553 with either sharp cap or nina)
#3 jerahian
jerahian
  • Loc: Maine
Posted 13 December 2019 - 09:45 PM
The ZWO native driver allows you to set the offset for the sensor, whereas the ASCOM driver for it does not.  So, I always use the native driver if the client app you are using supports it.
Separately, if you are asking whether you can use native for one camera and ASCOM for the other, the answer is yes.  As I already mentioned, I use the native ZWO driver in NINA for my ASI1600MM and the ASCOM driver in PHD2 for my ASI290MM-Mini.
I hope that answered your questions.
GL&CS.
  • pgs/sdg and OldManSky like this
#4 poofer
poofer
Posted 13 December 2019 - 10:03 PM
Thanks will try this. Pat
#5 DrGomer
DrGomer
Posted 13 December 2019 - 10:07 PM
Ascom does let you set offset. It's under the options settings.
  • CCD-Freak and jdupton like this
#6 jerahian
jerahian
  • Loc: Maine
Posted 14 December 2019 - 07:34 AM
Oh yes, that’s right.  It was at the sequence item level where it couldn’t be controlled.  Forgot specifically since I hadn’t used the ASCOM driver for my main camera for a while.
