bak 4 prism
14 replies to this topic
#1 publin
publin
Posted 14 December 2019 - 11:50 AM
HI  ALL!    as  an  new    member   and  a  vintage    bino's    collector   I   have   a  question   about  bak4  prisms  on   vitage  bino's  .   when   start  to  have  bak4   on bino's   and   in particular   in   russian /  german  items?  I  have   bpo5  8x30 [russian]   and  steiner  bayreuth  8x30  and  japan made   sears  10x50  all of   them   good  and crispy   emage   optic  but   bk7  prisms!   thanks for   answers!
#2 asphericalaberration
Posted 14 December 2019 - 12:01 PM
Can't speak to the German/Russian timeline, but nearly all of my vintage Japanese bins have Bk7. A few upper-end bins had Bak4 prisms going back into the 1940s (probably further). Bak4 has been marketed as "better" for a long time, so consumers think of it as "better." It's more accurate to view Bk7 and Bak4 as different types of glass with different properties. Which of the two is "better" for prisms will depend on the overall design. As you've noticed, there's nothing wrong with Bk7 prisms, especially at a standard-width FOV. It will have the benefits of higher transparency and lower cost. Bak4 does tend to suggest a higher manufacturing budget, however.
Edited by asphericalaberration, 14 December 2019 - 12:47 PM.
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 14 December 2019 - 12:18 PM
You could find that your BaK4 prisms are not BaK4 - there is no standard for BaK4 and it seems some BaK4 is not even Barium, lots are a Phospherous crown glass.
One question is: Is there a specific spelling for the BaK4 bit - which are upper and lower case?
BK7 is somewhat odd, it would seem as being the standard glass used for optical benches and components. So if BaK4 is so good I would have expected most glass to have been BaK4 not BK7. Cost difference is irrelevant when the optical table is $20,000.
Doubt it is supplied but the correct designation of what you expect as BaK4 is 569561
Bigger aspect is the prism size. They can be small, especially if BaK4 is classed as greater cost then BK7 and that the 10x50's really more like 10x40's.
Binoculars are an area where it seems liberties can be taken, and are. Everything is locked away inside that body and you have little idea what the real situation is.
I was once "preached" to by someone at an RSPB binocular day, all he knew was to repeat BaK4, BaK4, BaK4. He didn't like me at the end. lol.giflol.gif
  • j.gardavsky likes this
#4 hallelujah
hallelujah
  • Loc: North Star over Colorado
Posted 14 December 2019 - 12:43 PM
https://www.cloudyni...9-bak4-and-bk7/
https://www.cloudyni...84-bk7-vs-bak4/
Stan
#5 publin
publin
Posted 14 December 2019 - 02:21 PM
thanks for  your  answer   but   still    bak4   have     higher   index  then  bk7 [ even  the  chines  bak4 ]    and  more the    schmidt - pechan   prisms  [ high end  bak4]   also   bak4 " produce"  round  eye pupil and  sharp  emage   edge to edge  and  much more  light  path   gathering  from the   objectiv  lens   [   reduce  loss  dispersing light ].  so  is it   realy   manufacturer   system  to   increase    bino's  cost   and    theirs profits?   I  have  also      bak4    bino's    and   I can see  the  advantage   of   emage   view   vs   bk7   somehow ....?!      as  I  gase   many  of  the  members  her  have  both   bak4/  bk7    bino's   certainly   not only  the   kind   of  prisms   influence  on   bino  QUALITY    but   yet the are  the   importent   ingredient    in  bino's ?
#6 pat in los angeles basin
Posted 14 December 2019 - 03:05 PM
An ingredient but  not the the sole important ingredient. I've had BaK4 stuff (kmart bins) that were utter crap and BK7 stuff  (kowa prominar) that was fantastic . What does that prove? Besides the fact that I want the next Kowa pair I buy to have the BaK4 glass! The Kowas BTW are great to work on, good mechanicals, great optics and precision fit on internals....   Regards, Pat
#7 Rich V.
Rich V.
Posted 14 December 2019 - 03:20 PM
It's not about "quality" of the glass, it's about using the glass that has characteristics best suited for the application.  Shorter focal ratios or wide AFOV eyepieces demand a higher index of refraction.  Bak4 is best suited for those applications.
A quote from Jay Reynolds Freeman in a post from another forum, http://www.science-b...1d7ab7f8c9a.htm :
"The big deal about BAK-4 has to do with total internal reflection.
The reason why many common prisms do not require metallic coatings in
order to reflect light inside them is a phenomenon called "total
internal reflection", whereby a light beam traveling in glass, that
hits a plane surface (one surface of the glass) at a sufficiently
shallow angle, will reflect with 100 percent coefficient of
reflection.  You can see this phenomenon when you are under water in a
swimming pool, with your eyes open or with a mask on.  Look straight
up, and you can see out of the pool.  Look upward at an angle, and you
see the reflected bottom of the pool.
    The catch is, that the critical angle beyond which total
reflection takes place, varies with index of refraction, and for
ordinary crown glass (like BK-7), it is just a hair less than 45
degrees.  Thus a prism that has to deal only with reflecting rays that
approach at 45 degrees can be made of BK-7, but one that needs to
reflect rays at angles much less requires either a reflective coating
or a material with a higher index of refraction.  The difference is
only a few degrees, but the fall-off from total internal reflection is
fast, and many binoculars with Porro prisms have fields of view wide
enough, and objectives fast enough, that BK-7 prisms will provide
total internal reflection on axis, but off toward the edges of the
field, one of the prism reflections is no longer total.  There are
four reflections in the prisms, and failure of total internal
reflection at one reflection or another causes the familiar shadowed
square that one sees on looking at (not through) the exit pupil of
binoculars that are so equipped.
    Notice that even if you look straight through a binocular with
BK-7 prisms, so that you are seeing the rays that form the image right
on axis, you can sometimes see the shadowed square.  You will be able
to see it if the binocular objective is fast enough so that rays at
the edges of the converging cone of light from the objective, are
sufficiently far from 45 degrees to experience non-total reflection at
one prism.  Some binocular objectives are faster than f/4.  Any
telescope of this speed would suffer some loss of light if used with a
star diagonal made of BK-7 or a similar glass, but I believe that most
objectives are slow enough [not] to make this a problem.  You can check by
looking at the exit pupil of the eyepiece with a star diagonal in place;
if it is shaded on one side, there is a problem."
  • Jon Isaacs, hallelujah, FrankL and 1 other like this
#8 asphericalaberration
Posted 14 December 2019 - 07:13 PM
I don't think so. It is part of the general goal of selling a range of products at different prices, however. Features help them make distinctions.
I have about 25 vintage Japanese porros with Bk7 prisms and another 5 or so with Bak4 prisms. Nearly all are ultra-wides, 10 degrees or higher. In the Bk7 sample, only one exhibits noticeable vignetting in daylight use that I attribute to the Bk7 prisms. (It's a Mayflower 7x35 that claims 12 degrees, for those curious.) I don't recall any issues in the others that I attribute to the prisms. They're generally a bit dimmer than modern bins, and several have a stronger color cast--but that's the coatings, not the prisms.
Keep in mind that during daylight, your pupils are contracted. They therefore fit entirely inside the bright, diamond-shaped center area that you see when you hold a Bk7 pair away from your eyes. The dimmer area on the edge is outside your vision. You don't see it. At night, your dilated pupils might reach the dimmer area, but minor dimming in peripheral vision is unnoticeable.
I'm delighted to find the occasional Bak4 vintage bin, especially at a wide FOV or short focal ratio. I prefer them, partly because in old bins Bak4 often indicates good quality throughout the instrument (there are exceptions). I have no prejudice against Bk7, however.
Edited by asphericalaberration, 14 December 2019 - 08:13 PM.
#9 Jon Isaacs
Posted 14 December 2019 - 07:34 PM
The dimming caused by diamond pattern affects the entire field including the center, not just your peripheral vision, its like a smaller exit pupil.
  • hallelujah and SMark like this
#10 asphericalaberration
Posted 14 December 2019 - 08:28 PM
I'm unsure of that. I've believed that contracted pupils during the daytime are in effect part of the optical train. They literally stop down or truncate the bin's exit pupil to the current diameter of the eye's pupil. If that's true, then in daylight use with contracted pupils the outer portions of the bin's exit pupil don't reach the retina because the iris is in the way. Is your comment directed at night use with dilated pupils? The daytime image defect in the Mayflowers mentioned above is the diamond-shaped vignetting you'd expect from Bk7. I believe I picked up this factoid up from Bill Cook's book (which I might mis-interpret or mis-remember).  Please persuade me.
Edited by asphericalaberration, 14 December 2019 - 08:39 PM.
#11 Jon Isaacs
Posted 15 December 2019 - 02:22 PM
You wrote this:
"At night, your dilated pupils might reach the dimmer area, but minor dimming in peripheral vision is unnoticeable."
If you look back at my post, you will see I was responding to you comment about ones dark adapted pupil. If the dilated pupil is large enough to reach the diamond region, the entire image is affected. The center is also dimmer than it would have been,  not just the periphery.
  • SMark likes this
#12 asphericalaberration
Posted 15 December 2019 - 02:53 PM
Ah, yes, thank you. I misunderstood. I should read before writing.
  • Jon Isaacs likes this
#13 Rich V.
Rich V.
Posted 15 December 2019 - 02:58 PM
Yes, according to the Binocular Optics and Mechanics chapter of Stephen Tonkin's Binocular Astronomy book, he points out that BaK4 is Schott's barium crown glass designation and has a refractive index of 1.5688 with a critical angle of 39.6°.  Chinese "BaK4" are phosphate crown glass formulations that have an index of 1.5525 and a critical angle of 40.1° which falls between Schott's Bak4 and BK7 glasses.  Schott BK7 has an index of 1.5168 with a critical angle of 41.2°.
Rich
  • Mr. Bill and j.gardavsky like this
#14 Jon Isaacs
Posted 15 December 2019 - 03:30 PM
I think it happens to all of us.
The worst is when I write a long response and then, before posting, I go back and read the post I was responding to and realize I'd misunderstood the post and the half hour I'd spent writing had just been wasted.
  • Albie likes this
#15 SMark
SMark
  • Loc: Atlanta, GA USA
Posted 18 December 2019 - 01:32 AM
There are a few higher quality vintage porro models that can be found with either Bk7 or BaK4 prisms. These include the FPO (Fuji) Bushnell Rangemaster and Featherlight 7x35, as well as the Kowa Wide Angle 7x35. With all of these models I have made night sky image comparisons, and in all cases the BaK4 prism models have offered the brighter images across the entire field of view. While the difference isn't necessarily striking, it is nevertheless obvious. Especially in the wide angle models.
For this reason, there are but a very few Bk7 loaded wide angle 7x35 binoculars in my collection. I tend to disqualify any vintage wide angle binocular with Bk7 prisms, unless it offers something otherwise unique.  But as mentioned above, BaK4 prisms were generally only offered in the higher quality models anyway. Whereas today they are used almost universally.
  • hallelujah and Grimnir like this
