Sharpcap PA with guide scope?
6 replies to this topic
#1 okietwisterdan
okietwisterdan
  • Loc: Oklahoma
Posted 15 December 2019 - 04:53 PM
Just got all the equipment I need to start auto guiding. I will be using a ZWO asi224mc for guide camera with an at72ed as a guide scope mounted on an at115edt for imaging. I am using a DSLR for main imaging cam and an eq6-r pro mount.
I've never used Sharpcap polar alignment, and never done olate solving. Can I use the guide cam and guide scope for PA? Can I use that for plate sloving as well? Or should those only be done through the main imaging cam and main scope?
I understand that the DSLR won't work with Sharpcap.
#2 mikefulb
mikefulb
Posted 15 December 2019 - 05:08 PM
I polar align with my guide scope all the time.
  • AndrewXnn and Dynan like this
#3 AZ Maverick
AZ Maverick
  • Loc: Prescott, Arizona
Posted 15 December 2019 - 05:21 PM
Yes, the guide camera will work fine for Polar alignment with SharpCap.
I use my 60mm 240mm focal length guide scope with ASI120MM-S guide camera with SharpCap to Polar align all the time.
SharpCap has its own plate solver for polar alignment that works well.
For plate solving an actual image, you will need to plate solve with the actual image taken by your DSLR and not whatever the guide scope is looking at using whatever plate solving program you choose.
Edited by AZ Maverick, 15 December 2019 - 05:22 PM.
  • Stelios likes this
#4 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 15 December 2019 - 06:19 PM
I just started plate solving myself and yeah you use the imaging camera because the plate solving is to properly frame your object. I use Astrotortilla and you will have to do some reading about it because to get it to work efficiently you have to do some set up such as knowing the size of sky your imaging train occupies. But it’s not that complicated
#5 DuncanM
DuncanM
  • Loc: Arizona Sky Village or the rain forest
Posted 15 December 2019 - 06:26 PM
You can use the guidecam for plate solving but you need to ensure that the guide camera and imaging camera are precisely aligned so, that the centre of each camera's frame points at the same point in the sky. Ideally, both cameras would have the same rotation.
  • Dynan likes this
#6 Stelios
Stelios
  • Loc: West Hills, CA
Posted 15 December 2019 - 06:30 PM
You *should* use the guidescope for Sharpcap. The larger field of view will be a big help, and lack of alignment (if any) with the main scope is immaterial.
You *should* use the main camera for plate-solving. It may be possible to do it with the guide camera if you go to a lot of precise alignment hassles, but it really is completely pointless--for acquisition with a DSLR, you can't use Sharpcap anyway, and both SGP and N.I.N.A. (also other programs) will support platesolving with the main camera.
  • GoldSpider, AndrewXnn, Dynan and 1 other like this
#7 okietwisterdan
okietwisterdan
  • Loc: Oklahoma
Posted 15 December 2019 - 08:30 PM
Thanks for your help everyone!
