Hi all, as some of you may be aware, I'm interested in developing a colour calibration method for the planets, similar to that performed for DSO imaging. While it is usually easy to select a colour shift for the gas giants, calibrating for planets with a single hue (such as Neptune and Uranus) is more problematic as it is hard to determine the colour shift required.
DSO imagers use a standard G2V star to calibrate their images (see here and here for examples), so I thought I might try a similar technique for planetary.
Recent conversations with Christophe Pellier (and others) have caused me to investigate a G2V star near to Uranus (similar RA but 10* higher in declination) as a possible calibration star to see if the method has any merit. The star in question has designation HIP 9911 (HD 13043), a +6.88 magnitude G2V star with a similar size and colour to the sun.
Last night was clear, with no wind or moon. In the suburbs of Melbourne, Australia I was able to find Uranus readily, and took a 10 minute video with my ASI224MC (with ZWO IR cut filter) on a C9.25 attached to an Evolution mount, Teleview 2.5x PowerMate with gain 375 at 10 fps, and the result looks pretty good. I then turned my attention to finding HIP 9911, which was made more difficult because I cannot see this star through the spotting scope due to light pollution from the city, and the pointing accuracy of the Evolution mount is never really that good. After a number of attempts I removed the Powermate and tried with the camera at native resolution, finding a star that looked promising on the screen. SkySafari told me that there was a 10th magnitude star (TYC 4689-0890-1) underneath HIP 9911 and what appeared on my screen looks like what I expected. I took some videos of that star, noting how high the red component was from this star in the histogram, even though I was expecting it to be more pure white. Just before packing up I suddenly remembered that I forgot to remove the IR cut filter from the PowerMate and place it on the un-barlowed camera
. Fortunately I was able to fit the filter and take a 2 minute video of the star, with gain 375 at 77fps, trying hard not to saturate the frames by keeping the gain low.
I stacked the video of the star in AS!3 in the normal way, stacking 50% of the frames with 3x drizzle, and sent it to Registax 6, where I told it to auto-balance the RGB values (with no sharpening), the same method I use for the planets which normally gives good results. Registax pulled out the parameters r1.12, g0.93 and b1.08, which are not significantly different from the values it normally produces for the larger planets (an encouraging sign). The difference in the star colour can be seen in the first image below. The as-captured image of the star does look a little green, while the corrected image has lost this colour cast, however it still looks a little red to me, maybe it's supposed to be a little orange/yellow? I don't know how Registax calculates the automatic correction required, however it seemed to do a good job in the past so I continued to use it. (This image also shows that maybe my collimation isn't up to scratch as well).
I then applied the same colour shift to my Uranus image, which is shown below as the second image. The planet comes up looking bluer (with maybe a touch of a rosy glow on the north pole eh Darryl?
) but the green tinge has definitely been removed, which is a similar effect to what I noticed previously with Jupiter and Saturn.
So finally, submitted for discussion is the completed (dare I say colour corrected?) image of Uranus and its moons shown as the third image, with the system shown 50% larger than captured. WinJupos shows the moons dead on target, better than I've seen before. No sign of Miranda unfortunately, it just wasn't far enough from the planet to be evinced.
Q1: Is this an accurate, fully colour corrected image of the planet? A: Hardly, I would need more specialised equipment to determine that for certain, I'm not even really 100% certain that I imaged HIP 9911 as my colour standard, let alone determining the actual colour shifts required other than letting Registax do its auto-correct thing.
Q2: Is the colour correction good enough as a first order correction? A: Hmmm, maybe? I'll leave that for discussion here (assuming you've made it this far, I'm shocked at how long this essay currently is
Comments, criticisms and advice welcome.
Thanks, Andrew.
Edited by Tulloch, 16 December 2019 - 10:58 PM.
