Sv AT1010 questions
4 replies to this topic
#1 rongatlin7
rongatlin7
  • Loc: Riverview, Florida
Posted 26 December 2019 - 04:48 PM
Is there a way to make my SV AT1010 80mm Refractor,bino viewer friendly?
#2 junomike
junomike
  • Loc: Ontario
Posted 27 December 2019 - 08:07 AM
Using an OCS (usually 1.6X - 2X ) you should be able to reach focus
If you prefer not to use an OCS than you can test the back focus by focusing a piece of paper on the moon (move the paper until the Moon is in focus on it).
You'll need 5"+ to be able to reach focus without using an OCS and will need a short optical path Diagonal (I use a Baader Prism) and a threaded attachment to the BV (to keep things short as possible)
In general using an OCS is a far easier option.
#3 rongatlin7
rongatlin7
Posted 27 December 2019 - 09:31 AM
Thanks! I was read somewhere that said that a barlow lens would work. I don't have a barlow, so I tried my 2.5 powermate. It works, but the magnification is higher than I would like. Is there an ocs that is less than 200 dollars? Thanks again.
Edited by rongatlin7, 27 December 2019 - 09:32 AM.
#4 junomike
junomike
  • Loc: Ontario
Posted 27 December 2019 - 05:37 PM
There might be but we need to know what BV you have.
#5 rongatlin7
rongatlin7
Posted 27 December 2019 - 07:12 PM
Sorry. I have a stellarvue bino viewer that came with my SV80BV. I have no problem with the 2.5 powermate,other than the higher magnification. Maybe something in the 1.6 to 1.8 range might be better. I would also like to use this on my 10 inch dob.
