Truly wireless setup without limitations - Raspberry Pi + Remote USB 3.0
100 replies to this topic
#101 Saltman101
Saltman101
Posted 09 December 2020 - 11:37 AM
Hello
New to the board and I am following up to see if you are still using the Virtual Here on the RaspberryPI for the connection and if any new info is available. I am planning on setting this up for may setup outside on my patio and using the WIFI connection to connect to my desktop in the house. It is running Windows 7 Pro so I hope it will work.I have a very strong signal since the router is about 20' from the scope thru a brick wall.I plan on running Celestron CPWI along with Starsense, and Stellarium to control mount. I will be shooting with a Canon camera  running Astrotoaster. The way I read the post  I can run all the programs on my desktop inside and connect to the Raspberry running Virtualhere to control the outside mount. Am I correct in assuming this will work for my setup?
