DIY Counter Weight for C5+
6 replies to this topic
#1 Old Man
Old Man
  • Loc: Indiana
Posted 05 January 2020 - 12:31 AM
Davetavt01,  I would love to see your DIY solution for the counter weights on a C5+ mount.
  My original post was deleted due to the rules in TOS. If you can still post the pics I would like to see your solution.
           Thanks,  Mike
#2 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 05 January 2020 - 03:05 AM
My solution uses a long bolt (1/4-20) with the head cut off, two nuts, one wing nut, two large slightly bent washers, and one or more weights. The end of the long bolt is notched so it can be unscrewed with a flat head screwdriver. You do have to make sure that the weight is positioned so it does not come into contact with the the drive base or the wedge.
CFE1B9A6 25B5 48D2 AC80 B6FA1B2C31AE
B23D9724 8161 46E8 A6A9 D2B4C13234E5
C51C854E FE29 4F6F 990B 91A402A3CDA5
  • shredder1656 likes this
#3 Old Man
Old Man
  • Loc: Indiana
Posted 05 January 2020 - 01:50 PM
That is not to bad. I had not thought of a weight quite that big in diameter. How long is the threaded rod you are using?
   I may have to make up something similar.
     Thanks,  Mike
#4 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 05 January 2020 - 04:37 PM
The rod is about 5.75 inches long. Sometimes i use sockets from a socket set or stacks of washers too for more precise balance in addition to the weights.
#5 StefanM
StefanM
  • Loc: Germany
Posted 13 January 2021 - 04:14 AM
Hey Mike,
the thread on the C5+ arm is 1/4 that is common in Photo Equipment. So on my C5+ I use Gimbal Counterweights. They came in different sizes. You can screw them directly to the mount and add as many as you need by stacking them on top of each other.
I use these Counterweights:
https://tinyurl.com/y4uzg5o3
I also build myself a "plug & play" slidable solution out of a rod and clamp (Also Photo Equipment). The rod is screwed to the C5 arm. The counterweights are stacked onto the clamp that slides on the rod.
Rod: https://tinyurl.com/y3hhf2dy
M12 to 1/4 adapter for the rod: https://tinyurl.com/y6xs5rfj
Clamp: https://tinyurl.com/y4e4uhuy
But I mostly stick with the counterweights directly screwed to the C5 arm if needed.
Greetings from Germany,
Stefan
Edited by StefanM, 13 January 2021 - 07:58 AM.
  • Daveatvt01 likes this
#6 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 16 January 2021 - 04:19 PM
The gimbal counterweights are neat!
#7 StefanM
StefanM
  • Loc: Germany
Posted 17 January 2021 - 06:38 AM
Yes and installable right of the box. wink.gif I use the 3 different available sizes to set approx. the weight I have added with extra equipment and then make a test by turning the mount by hand from one side to the other. If it feels right and balanced I’m pretty sure the motor can handle it. It’s a sturdy little mount.
Edited by StefanM, 17 January 2021 - 06:57 AM.
