Summer Milky Way mosaic
7 replies to this topic
#1 Michal1
Michal1
  • Loc: Czech Republic, Central Europe
Posted 05 January 2020 - 07:29 AM
I have finally found time to process this 4-plane mosaic of the region between Cygnus and Aquila. Coincidentally it can be considered my aniversary photo because I bought my Pentax 6x7 nearly exactly 10 years ago.
The shots were taken in 2018. The sky was covered by thin clouds nearly the whole season. This is why the stars are a bit hazy. Each plane was exposed for 40 min at f/4. The lens was Takumar 105mm and film Kodak E200. I used my homemade vacuum back to hold the film flat. The mount was aligned with the PARot program. The processing was the most difficult part. First I removed the vignetting and background gradients from each individual frame. I did it manually in Photoshop by selecting the dimmer/brighter areas and adjusting the levels. Increasing the contrast temporarily by an adjustment layer alowed me to make the corrections exactly. The mosaic was assembled in Photoshop again, using the photomerge function. This unfortunatelly doesn't leave a completely seamless result. After cropping the image there were some empty areas near the corners of the image. I had to fill them using the Content Aware Fill function. If you compare carefully the image with others, you can note that some stars don't match.
Here is the photo in a higher resolution.
  • Joe F Gafford, okiestarman56, Alen K and 4 others like this
#2 Alen K
Alen K
Posted 05 January 2020 - 08:01 AM
I'm not sure what I think about faking stars in the corners but if you hadn't said anything I would be none the wiser. Nice image in any case.
  • Simcal likes this
#3 jerobe
jerobe
  • Loc: Southeast Texas
Posted 05 January 2020 - 09:10 AM
Excellent.  A lot of work was involved in this image! Thanks for sharing.
#4 Simcal
Simcal
  • Loc: Caledon, Ontario
Posted 05 January 2020 - 10:42 AM
I would agree with Alan, not sure we want to put fake data out there. Better just leave it accurate but incomplete.  Never know if it could be misinterpreted in the future by someone.
  • Todd N likes this
#5 TxStars
TxStars
  • Loc: Lost In Space
Posted 06 January 2020 - 01:53 PM
I like the overall look of the color you have there.
#6 Michal1
Michal1
Posted 06 January 2020 - 07:33 PM
Thanks all!
As for the fake stars, from my point of view almost anyone does astrophotography for science. Its main purpose is to produce aesthetically pleasing images and this is the rule I follow. If someone created a photo with two North American Nebulas, I would feel a bit heretic, too, but why not. We also have surrealistic paintings.
#7 whwang
whwang
Posted 07 January 2020 - 03:41 AM
Hi Michal,
This is a fantastic image.  It's really nice to see such a high-quality film image in the digital era.  Thank you for sharing.
I use content-aware fill or brushes to fill in small empty spots or to remove satellite tracks, all the time.  However, I don't use this to create bright stars or any noticeable bright objects.  Creating bunches of faint stars in small areas where there are supposed to be only faint stars, is not exactly scientifically correct, but does not hurt the value of a picture.  This helped me to catch those who steal my pictures too.
Wei-Hao
#8 Nightfly
Nightfly
  • Loc: Dark Skies, Maine
Posted 08 January 2020 - 07:30 PM
I love the rendering of your fine astrophotograph Michal.  The thin clouds enhanced the brightest stars nicely !  Good work and glad the E200 is holding up !
Thanks for sharing your wonderful image!
