Poor QHY repair service; this is a slow boat to China
28 replies to this topic
#26 Hobby Astronomer
Hobby Astronomer
  • Loc: Texas
Posted 14 February 2020 - 03:25 PM
I am not taking the side of QHY, but I needed some assistance with my QHY11 cooler. They charged me only about $60 for everything including the shipping. Camera has worked great since. Took about 8 weeks.
It is an interesting experience to work with them.
HA
#27 maxmir
maxmir
Posted 16 February 2020 - 08:16 AM
I purchased my QHY128C two years ago. I never really got past plugging it in and testing operation.
This fall I tried again. It could not produce an image.
It was repaired in China after two months. Now it downloads images fine. I found another problem as I started using the camera.
I first noted that  the image center was offset by about 1000 pixel in X and 500Y. The sensor appears centered using a ruler in the camera .
The QHY128C comes with an adjustable front end piece with three screws
that allows for some lateral adjustment. However, a 1000 pixels exceeded the range. I have a lathe and removed 2mm from the adjustable front piece.
I am was now able to center a star and rotate the camera in the focuser without lateral shift. Offsetting the sensor took 2-3 mm.
I could not understand why the image was so far off center.
Next I did a plate solve ( this is where the plot thickens )
I measured 1.21 arcsec per pixel and FOV 2.03 x 1.37 degrees with TheSkyX's image link plate solution.
The scope in an AP130 f6. I verified that the scope has a FL of close to the specified 780mm focal length using a ruler.
The predicted FOV should be about 2.64 x 1.76 degrees at 1.58 arcsec per pixel.  This is using  a 780mm FL scope and a 128C camera specified with 6036 x 4028 pixels  @ 5.97u.
The plate solution at  a FOV 2.03 x 1.37 and 1.21 arcsec per pixel suggests that scope has 1020mm  FL. This is most decidedly not true.
I have determine that the camera likely has much smaller pixels ( about 4.7-5.0u) and is not using all the pixels on the sensor.
I am keeping in mind the fact that active imaging area is substantial offset.
I don't know if it is possible to install a 367C sensor and configure to readout a sub-frame using firmware.
The 367C has 4.88u. This would fit the measured offset and plate solution.
Kind of sucks too. I want the FOV.
What do you think?
Max
#28 maxmir
maxmir
Posted 16 February 2020 - 08:17 AM
Started another thread.
https://www.cloudyni...sed-up-qhy128c/
#29 cccha
cccha
Posted 17 February 2020 - 12:03 AM
This needs to be confirmed. It should not be a deviation of the mechanical center, because 1000 pixels are very large and account for 1/4 of the whole in the vertical direction. This deviation can be seen intuitively. Can you intuitively see that the chip has a large deviation?
