Reichert looking for ID and manual
4 replies to this topic
#1 skluever
skluever
Posted 06 January 2020 - 02:07 PM
Hi Everyone.  I stumbled across this forum looking for a manual for my microscope.
Nice to be here!
Can anyone put a model name / number to this one in the picture?  I know it's a Reichert from Austria, and possibly dating from the 1960s or 1970s.
And I am seriously looking for a user manual.  If you have any information, please let me know.
I specifically want to find how to align / adjust the phase contrast setup.  And I'm also not sure which condenser position to use with which lens.
Stephan
#2 nvmicro
nvmicro
Posted 06 January 2020 - 11:26 PM
Hello Stephan,
This is a Reichert Diapan.  The Diapan (and it's little brother, the Neopan) have an unusual fine focusing mechanism that is actuated by angling the coarse focus controls about a vertical axis.  Manuals are a bit tricky to obtain, but it is otherwise not an overly-complicated microscope.
The built-in illumination system (with 12V halogen lamp, focusable collector lens , field iris and filter wheel) is really the major difference between the Diapan and Neopan. (I notice you are missing a portion of the lamp holder)
wrt Phase contrast adjustment - here is a link to the Reichert phase contrast manual (albeit in combination with the more elaborate Zetopan model - but the concepts are the same) http://www.science-i...al_Contrast.pdf
As far as I can make out, I only recognize one of the objectives as a Reichert phase objective (red band) and if you look at it closely you will see the number 3 on it.  This number indicates that this objective is to be used with the condenser in selecting the #3 phase ring.  To align the phase rings (as per the linked manual above), it is easiest to do so with a phase telescope in place of one of the eyepieces.  These are regularly available on eBay such as this listing here:https://www.ebay.com...353.m1438.l2649.
Hope that helps
John
#3 Microscopy
Microscopy
Posted 07 January 2020 - 09:19 AM
I have one of those as well. Great microscope!
"And I'm also not sure which condenser position to use with which lens.". That all becomes clear, once you have a phase telescope: the phase anulus of the condenser should match the one in the objective.
nvmicro: "albeit in combination with the more elaborate Zetopan model - but the concepts are the same". You're right and the condensers for the Neopan/Diapan fit into the condenser slider for the Zetopan.
Edited by Microscopy, 07 January 2020 - 09:22 AM.
#4 skluever
skluever
Posted 07 January 2020 - 04:08 PM
Thanks guys.  This is really fantastic help!
The lamp holder is not a problem - just out for repairs by my son.
I do notice from the manual that there's something else that I'm missing, named the "wide-field lens".  Hopefully I can live without it?
So it's clear I have to get hold of a phase telescope.
As for the phase objectives:  there are more of them on this microscope.  They are labelled with a "Ph" which I believe indicates it is a phase contrast objective.  And when I unscrew them, I can clearly see the ring inside.
Thanks again for the help
Stephan
#5 Microscopy
Microscopy
Posted 08 January 2020 - 09:33 AM
Reichert objectives labeled with "ph" are for phase contrast, objectives labeled with "phA"  for anoptral phase contrast. Both use the same condenser, but the objectives are different.
