Unknown option in Audiostar menu?!
9 replies to this topic
#1 Piet Le Roux
Piet Le Roux
  • Loc: Bloemfontein, South Africa
Posted 07 January 2020 - 02:49 PM
I have a LX90 with Audiostar controller with patched firmware A4s4. I was doing a test run in polar mode when I went through the menu and in "Setup" under "Telescope"  I found this item: "Germ. Mnt. Adj.", when I press "Enter" it just gives a beep and nothing more. Does anyone  know what it is for? Is it part of the new A4S4 firmware or something the patch added ?
#2 Ericco79
Ericco79
  • Loc: Charlotte, NC
Posted 07 January 2020 - 02:54 PM
Hey Piet,
Just a guess but I'm thinking it's "German Mount Adjustment" for German Equatorial Mounts. Possibly for polar alignment or such. Since you're on an LX90 which is a Alt / Az mount it won't apply in your case. But the audiostar controller can be used on both Alt / Az mounts and equatorial mounts.
I'm not sure if this helps or not but hopefully it points you in the right directions.
#3 OzAndrewJ
OzAndrewJ
Posted 07 January 2020 - 03:11 PM
Gday Piet
Errico is correct, it is for adjusting a GEM mount
It should normally get cut from the menus when you select a mount
I know Meade have done big changes to the mount selecting routines
in A4S4 but didnt see that quirk.
#4 Piet Le Roux
Piet Le Roux
Posted 07 January 2020 - 03:24 PM
Thanks for the quick response!
Yes its not a GEM mount but I am in polar mode(not Az/Alt) on a wedge and  I thought it could be something useful. If I did have a GEM mount what would I do with it ? The other question is the 3 star alignment : will that work on a LX90 and what could I benefit?
#5 OzAndrewJ
OzAndrewJ
Posted 07 January 2020 - 03:51 PM
Gday Piet
Sounds like they have stuffed something up in rearranging the code.
The menu in question should only appear for true GEMs, not Polar forks.
The 3 star wont work and wont benefit you with a fork
Basically, the 3 star does a std 2 star align using stars on the same side of the meriden.
It then flips for the third star, and that error is then used as a crude approximation of cone error.
  • Piet Le Roux likes this
#6 Piet Le Roux
Piet Le Roux
Posted 07 January 2020 - 11:22 PM
Ok I get it. The fork mount cannot point slightly east or west when the mount is pointing to the celestial pole which would result in cone error but it could be pointing slightly north or south when I am pointing to my polar home position before I do a 2 star alignment, how do I guard against that  ?
#7 OzAndrewJ
OzAndrewJ
Posted 07 January 2020 - 11:28 PM
Gday Piet
Any North/South ( ie DEC ) error when doing a polar align, is irrelevant ( as is having a slightly wrong RA )
In a 2 star, when you centre the first star, the mount does a synch and it then measures the error between there and the second star, ie where you started is effectively irrelevant, other than to assist in getting you close to the first star.
#8 Piet Le Roux
Piet Le Roux
Posted 07 January 2020 - 11:45 PM
PS The three star alignment and  Germ. Mnt. Adj does appear in the menu when a LX90 is selected but does nothing : both just beeps. So you right its just a  quirk. Something that could be removed with a patch??
#9 OzAndrewJ
OzAndrewJ
Posted 08 January 2020 - 01:20 AM
Gday Piet
Anything is possible after enough red wine, but as i mentioned to you prev,
i really, really, really dont like A4S4 and dont want to waste any life force on it :-)
#10 daslolo
daslolo
  • Loc: Camano Island, WA
Posted 18 February 2020 - 05:57 AM
Stick to A4S2 on lx65?
i don't see a changelog on meade website
