Rewarding objects for spectroscopy AND astrophotography
astrophotography beginner dslr
31 replies to this topic
#1 mwr
mwr
  • Loc: Germany
Posted 11 January 2020 - 11:03 AM
Having the star analyser installed in a filter wheel of my slow (f/9.4) and low budget imaging system https://www.cloudyni...-100/?p=9742246), I'm always in search for objects that are
1) astrophysically interesting,
2) bright enough (m<11 mag] and
3) are rewarding objects for doing low resolution slitless spectroscopy AND astrophotography (once the object is on the sensor, both aquisitions can be made consecutively without changing the system by simply turning the filter wheel)
The famous Blue Snowball (NGC 7662) is such an object: Low-ionisation emission regions and other microstructures can be imaged in this bright planetary nebula and a low resolution spectrum can be recorded due to its relatively small diameter:
For plasma diagnostics the [O III] lines around 5000 Angstrom should be resolved. However, in my spectrum this is not the case. Only a shoulder is visible. The first derivative of the spectrum reveals the overlaped lines (keeping well in mind that star analyser spectra of non stellar objects should normally not be processed in this way: https://www.cloudyni...tive/?p=9721131
After background and continuum subtraction the Balmer decrement was calculated. The excitation class was calculated by assuming that the area under the non-resolved [O III] lines can be used as a measure for the sum of N1 and N2:
The same object recorded with superior equipment:
http://www.krannich-...pn.html#NGC7662
Here are some other examples of rewarding objects:
https://www.cloudyni...i-and-ngc-1555/
http://www.spectro-a...p?t=1392&p=6342
https://www.cloudyni...77-with-sa-200/
https://www.cloudyni...et-star-wr-136/
Hubble's variable nebula NGC 2261 (no star analyser spectra found so far) - to be recorded
The Pleiades (B and Be stars) - to be recorded
Thor's Helmet with its central Wolf-Rayet star - to be recorded
More suggestions are highly welcome! I'm slowly running out of objects....
Edited by mwr, 11 January 2020 - 01:38 PM.
  • robin_astro, giorgio_ne, GoFish and 1 other like this
#2 robin_astro
robin_astro
Posted 12 January 2020 - 07:37 AM
Eta Carinae but sadly not for us northerly observers though
https://www.cloudyni...um-01-feb-2016/
and while we wait for the next bright  comet, perhaps  C/2017 T2 (PanSTARRS) will be bright enough ?
https://britastro.org/node/20186
  • mwr likes this
#3 gfamily
gfamily
  • Loc: North Cheshire, UK
Posted 12 January 2020 - 07:48 AM
I'd have thought that Albireo or some of the other distinctly coloured binaries would make interesting targets - not necessarily for spectroscopic analysis, but to show how the spectra have different profiles.
https://www.skyandte...l-and-imagined/
I don't have a Star Analyser, but I bought a 100 /mm grating that fits in front of my 50mm dSLR lens and gives nice images (here of the Plough)
edit for spelling
Edited by gfamily, 12 January 2020 - 07:53 AM.
  • mwr likes this
#4 robin_astro
robin_astro
Posted 12 January 2020 - 07:49 AM
Christian Buil's iconic shot of an "ordinary" star field in Perseus using the Star Analyser revealing the true nature of the stars it contains
http://www.astrosurf...lyser/wr5_2.jpg
  • JoeVanGeaux and mwr like this
#5 mwr
mwr
  • Loc: Germany
Posted 12 January 2020 - 10:20 AM
Excellent suggestion! The Swan bands should make a good target. I have just updated the comet files in my "Cartes de Ciel" programme and the brightness of C/2017 T2 should be around 9 mag. I will try to record a spectrum using the SA-200 as objective grating (as shown on your website). The last bright comet I have imaged was 46P/Wirtanen using my portable setup but at that time I wasn't aware of the fact that comets are actually good targets for low resolution spectroscopy (https://www.cloudyni...et-46pwirtanen/ https://www.cloudyni...as-polar-scope/).
Edited by mwr, 12 January 2020 - 10:21 AM.
#6 descott12
descott12
    Vendor - Solar Live View
  • Loc: Charlotte, NC
Posted 12 January 2020 - 05:02 PM
I had wanted to capture all the stars in M45. This is my first. I believe it is Alcyone but I am not 100% sure I was on the correct star. It should be a B7iii. My spectrum in not inconsistent with a B or B7 but I seem to have trouble getting deep absorptions in 4000-5000 A range
#7 robin_astro
robin_astro
Posted 12 January 2020 - 09:57 PM
Alcyone is a Be star which could explain the absence H alpha and perhaps weak H beta (The emission is probably fillling in the absorption at this resolution). Not sure what all those grey lines are as only the Balmer lines will be particularly strong in a B7 star but yes the spectrum does look rather "soft"  Was the seeing and focus ok at the time?
Edited by robin_astro, 12 January 2020 - 09:59 PM.
#8 mwr
mwr
  • Loc: Germany
Posted 13 January 2020 - 02:01 AM
What a coincidence! Yesterday night I set up my SA-100 as objective grating (with FD 200mm) to get ready for PanSTARRS and the Pleiades were my first test object. Alcyone is indeed detectable as a Be star (the Fujifilm X-A1 is unmodified and the spectrum is uncorrected and quite noisy because I stacked only 6 frames but H alpha is definetly in emission):
A nice object. I need to get more frames and analyse the other stars of this cluster..... (Richard Walker has published the spectra of the main stars of this cluster in his Atlas).
Edited by mwr, 13 January 2020 - 08:57 AM.
#9 mwr
mwr
  • Loc: Germany
Posted 14 January 2020 - 01:57 PM
The spectra of B star Atlas (27 Tauri) and Be star Alcyone (25 Tauri) - the two brightest stars of the cluster -  were now rectified:
#10 descott12
descott12
Posted 14 January 2020 - 02:33 PM
Those look great. Nice job.
#11 mwr
mwr
  • Loc: Germany
Posted 14 January 2020 - 03:24 PM
Well, the lines could actually look better. When using the SA-100 as objective grating the dispersion should be (theoretically) at 2.5 Angström per pixel (the measured value with RSpec of 2.4 A/Pixel compares well with this value). However, the line broadening due to spectral coma should be eliminated (no converging beam in the objective grating setup) and the maximum resolution is theoretically at 8.5 A (3.4 times the dispersion for a Bayer color filter array). I have measured an average FWHM of approx. 25 A of the Balmer lines, which is considerably higher than 8.5 A. Obviously, the achievable resolution is seeing-limited in my case :-(
#12 robin_astro
robin_astro
Posted 14 January 2020 - 04:01 PM
Another suggested target for this list for observers further south than me is R Aqr.  A crazy symbiotic star system consisting of a white dwarf and a Mira embedded in a complex nebula from previous interactions between the components and polar jets.
https://en.wikipedia.../wiki/R_Aquarii
It is the subject of  pro-am monitoring currently and is showing lots of strong emission lines at the moment though they might be tough to resolve at Star Analyser resolution
http://spectro-aras....start=10#p13600
Cheers
Robin
  • mwr likes this
#13 mwr
mwr
  • Loc: Germany
Posted 18 January 2020 - 07:15 AM
Two days ago I tried to record a spectrum of PanSTARRS which is yet a rather small and faint object. A small coma with a barely detectable tail were visible (image was taken with an FD 300mm; 30 frames at 60 sec were stacked):
However, a spectrum was not visible when using the SA-200 in the converging beam of my 4-inch Maksutov-Cassegrain (20 frames at 400 sec were stacked; due to the movement of the comet the first order images of the stars and their corresponding spectra are blurred because it was stacked "on the coma" using a constant offset; the Wolf-Rayet star WR 4 was nearby and produced an emission line spectrum)
The integrated magnitude of PanSTARRS should rise from 9 to 8 mag in spring but I'm quite pessimistic that this rise is large enough to get a spectrum with my low resolution and slow (f/9.4) setup :-(
Has been somebody able to get a spectrum of PanSTARRS so far ? Neither the BAA database nor the ARAS database contains one.
Edited by mwr, 18 January 2020 - 07:19 AM.
  • descott12 likes this
#14 robin_astro
robin_astro
Posted 18 January 2020 - 07:49 AM
I've not seen any spectra of C/2017 T2 (PanSTARRS) yet but I plan to try (perhaps with the ALPY 600) if I get the chance. The background stars are a big problem with the Star Analyser where it is currently but perhaps it will be better in April when it moves out of the Milky Way into Camelopardalis
https://britastro.or...17t2_Page_1.png
Cheers
Robin
Edited by robin_astro, 18 January 2020 - 07:56 AM.
  • mwr likes this
#15 mwr
mwr
  • Loc: Germany
Posted 19 January 2020 - 05:31 AM
Cheers
Robin
Uwe Zurmühl has proposed to use a "beam blocker" construction to block the crowded zero order images of the field stars (Spektrum 55, 1/2019 p. 20): http://spektroskopie...Spektrum55.pdf
I will try it ...
#16 robin_astro
robin_astro
Posted 19 January 2020 - 12:58 PM
Here is 2017 T2 PanSTARRS from last night with the ALPY. Mainly scattered sunlight (divided out using a nearby G2v star) but some emission lines, particularly CN in the UV at 390nm
As seen in the guider (11x10s)
The raw sky subtracted spectrum 15x300sec (The faint spectrum above the coma is a field star which drifted through the slit during the exposure)
The calibrated spectrum and divided by G2v star
Cheers
Robin
  • giorgio_ne, RobboK and mwr like this
#17 descott12
descott12
Posted 19 January 2020 - 01:40 PM
Very nice. What does dividing by the nearby star do?
#18 mwr
mwr
  • Loc: Germany
Posted 19 January 2020 - 02:18 PM
Did you guide directly on the inner coma?
#19 robin_astro
robin_astro
Posted 19 January 2020 - 02:22 PM
It is a similar to the technique used on planets and asteroids. Most of the light from the inner coma comes from the scattering of sunlight from dust so  dividing by the solar spectrum gives the reflectance spectrum of the comet dust.  I chose a nearby star of the same spectral type as the sun as a substitute as it also experiences the same atmospheric extinction as the comet.
Cheers
Robin
#20 robin_astro
robin_astro
Posted 19 January 2020 - 02:26 PM
Yes. exposures were quite long (3sec I think) but small errors did not matter too much as long as the brightest  part of the coma stayed in the slit
#21 mwr
mwr
  • Loc: Germany
Posted 21 January 2020 - 04:59 PM
Beside the Pleiades there are more open clusters with Be stars as rewarding objects for astrophotography and objective grating spectroscopy (http://articles.adsa...ApJS...59..769S):
NGC 663 (letter S cluster)
h and chi Persei
alpha Persei cluster
and finally the Orion OB1 association subgroup 1a (northwest of Orion's belt) which is also a rewarding object for visual observers https://www.cloudyni...d/#entry7682143:
Astrophoto was taken using an Omegon MiniTrack; 10 x 1min; UHC filter; 50 mm Canon FD; suburban sky (18 mag/sqr arcsec):
Omega Ori and 25 Ori are bright Be stars within this cluster whose spectra were captured using the SA-100 as objective grating (FD 300mm; 30 x 30 sec; rectified):
Nearby is the beautiful carbon star W Ori:
https://www.cloudyni...copy/?p=9924925
Edited by mwr, 22 January 2020 - 03:51 AM.
  • giorgio_ne and descott12 like this
#22 mwr
mwr
  • Loc: Germany
Posted 26 January 2020 - 07:00 AM
Although low in the sky at my observing site (25°), the planetary nebula IC 418 (spirograph nebula) is a rewarding object for slitless low resolution spectroscopy because of its small diameter and high surface brightness (SA-200; 10 x 250 sec.). The bright central star is visible in the center of the shell:
Plasma diagnostics confirmed the low excitation nature of this object. Due to the non-resolved H alpha/[NII] lines, the balmer decrement was calculated using the H beta/H gamma lines:
A comparison with the high excitation planetary nebula "blue snowball" nicely illustrates the differences between the excitation classes when H beta and H gamma lines were normalized:
Another low resolution spectrum of IC 418 compares well with the spectrum presented above: https://www.cloudyni...copy/?p=9789039
Are some other spectra available that show the resolution of the H alpha/[NII] lines? BAA database contains only very few PN spectra.
Edited by mwr, 26 January 2020 - 02:20 PM.
  • robin_astro and descott12 like this
#23 robin_astro
robin_astro
Posted 26 January 2020 - 09:49 AM
There's one on Francois Teyssier's website with a LISA
http://www.astronomi...ry_Nebulae.html
Not sure where the fits file is though, perhaps in the ARAS database ?
Also a highly detailed professional one here
https://iopscience.i.../10.1086/133438
  • mwr likes this
#24 robin_astro
robin_astro
Posted 26 January 2020 - 09:54 AM
Also one in the ARAS forum but again no fits file
http://spectro-aras....it=ic418#p12101
  • mwr likes this
#25 descott12
descott12
Posted 26 January 2020 - 10:28 AM
Although low in the sky at my observing site (25°), the planetary nebula IC 418 (spirograph nebula) is a rewarding object for slitless low resolution spectroscopy because of its small diameter and high surface brightness (SA-200; 10 x 250 sec.). The bright central star is was visible in the center of the shell:
A comparison with the high excitation planetray nebula "blue snowball" nicely illustrates the differences between the excitation classes when H beta and H gamma lines were normalized:
This is REALLY great stuff.  I always want to run out to my observatory after reading your posts....but it is 10 AM and broad daylight now!
  • mwr likes this
Also tagged with one or more of these keywords: astrophotography, beginner, dslr
