Home made Binocular fork mount
3 replies to this topic
#1 tomb18
tomb18
    Vendor - AstroRotor
Posted 11 January 2020 - 07:32 PM
Hi
Recently I purchased an APM 100mm Apo Binocular with the APM center mount.  While the center mount is nice and compact and works well I found that as I increased the magnification to 60x and beyond, the vibration was just a bit too much.  Thus I started thinking about building my own fork mount.
The difficult part for this was coming up with decent bearings for altitude and azimuth. So I got to thinking and looking at the commercial APM fork mount, it seemed that the azimuth bearing is quite close in appearance  to the center mount bearing.  So I decided to use the existing az bearing and find ways for the Alt bearings.
Looking through the McMaster Carr catalog turned up the following 4 parts:
IMG 11012020 185423 (1080 X 1920 pixel)
I used a teflon bearing that fit a flange mount 3/4" shaft that had a 5/8" thread at the end. A thrust bearing made out of 1/8" teflon sheet provided the perfect spacing through the 1/4" aluminum arm.  On the other end, I added a 3/4" inside diameter roller bearing and then 3d printed a knob that held a 5/8" bolt.  The result, assembled looks like this:
IMG 11012020 185112 (1080 X 1920 pixel)
That took care of the azimuth.  I then purchased some 20x80 and 20x60 aluminum extrusions as well as a nice vixen dovetail mount from ebay.
IMG 11012020 185137 (1080 X 1920 pixel)
I wanted to have shaft encoders to use with a Nexus DSC so I drilled out and tapped one altitude axis and placed an AMT 101 encoder there with a 3d printed support.
The azimuth axis turned out to be more challenging.  I first started to drill through the shaft for the azimuth thinking I would add a shaft through the existing bearing.  Well the main shaft was far to hardened for me to do anything with it.  So instead I 3D printed a GT2 pulley which was a press fit on the outer azimuth bearing casing and designed a support for a smaller pulley with a shaft through to the azimuth encoder.
IMG 11012020 185155 (1080 X 1920 pixel)
The resulting complete fork mount looks like this:
IMG 11012020 185359 (1080 X 1920 pixel)
IMG 11012020 185221 (1080 X 1920 pixel)
The black box under the mount is the Nexus II DSC which I use with an Android tablet and Sky Safari.
Total cost was around $320, a lot of which was postage ordering the things from all over the place. So here in Canada I saved a cool $1000 or so over the commercial cost. (Money's gone.  I bought a mini-lathe with the savings) The aluminum arms were done on a Shapeoko 3 CNC mill but you could do the same with hand tools if you have the patience.
Hope this helps some adventurous ATM's.
Edited by tomb18, 11 January 2020 - 07:39 PM.
  • Diego, PrestonE, psandelle and 7 others like this
#2 yukosteel
yukosteel
  • Loc: Bellevue, WA
Posted 13 January 2020 - 02:57 PM
This is extremely nice DIY guide, thanks for sharing! Very cool result!
#3 Ken Watts
Ken Watts
  • Loc: Sun City, Az
Posted 16 January 2020 - 11:04 AM
Nice build!
#4 John Miele
John Miele
  • Loc: North Alabama
Posted 17 January 2020 - 01:27 PM
Outstanding!!!
