DobStuff Rocker box for my Serrurier Truss 12.5".
17 replies to this topic
#1 Cotts
Cotts
    Just Wondering
  • Loc: Madoc, Ontario
Posted 14 January 2020 - 02:39 PM
My 12.5" Serrurier Truss Newtonian is detailed here....
I needed a Dob mount for this scope.  And so i ordered a kit from DobStuff.  It took me about 3 weeks to assemble it all.  Staining and clear-coating took the most time since I waited a day or two between coats... I made every effort to stain it the same as the Teeter 'centre-box' and UTA..  The pictures speak for themselves.  I think my staining is a wee bit darker but close enough.
Pics here and in subsequent posts...
This telescope can now be successfully used as both an equatorially mounted Newtonian for photography and a Dobsonian Newtonian for visual observing... Taking advantage of the superb Lockwood mirror for both uses.
Other than routing the DSC wires the scope is ready for first light....
The dovetail seen here is a rare Losmandy 2 1/2" which holds the guide scope in EQ mode...
Dave
#2 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 02:42 PM
Another aspect:
A 3 1/2 dovetail for mountin in EQ mode.  A small Kendrick dew controller mounts on the velcros...
Dave
#3 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 02:43 PM
View #3:
Dave
  • airbleeder likes this
#4 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 02:45 PM
View #4
Dave
#5 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 03:10 PM
The Nexus DSC's work very nicely with the supplied 10 000 tic encoders....  I put the 'brain' up at the top for convenience.....
My thoughts on the DobStuff product.
Quality of wood - excellent.  Baltic Birch.
Fit:  Very nice as you would expect from CNC - cut wood.  There was a lack of pre-drilling holes, however.  e.g. when joining one side to the base there were pre-drilled holes in the base but no pre-drilled holes in the side.  I had to stick an awl in every hole to mark the location and then pre-drill myself.  Try doing that with two pieces of wood meeting perpendicularly......  Mark the first hole, drill, insert screw part way.  Mark the next two holes, remove screw, disassemble the two pieces, drill the two remaining holes.  Glue it and screw it. Then clamp it... wait for the glue to dry....  Had to do that for every join....  There's no way you could screw into that Birch without a pre-drilled hole...
Joinery:  The edges are joined by just butting one piece to another, gluing and screwing and subsequent clamping.   I know that most of the high-end dob makers use more sophisticated joinery which is likely to be stronger and retain orthogonality better.  The jury is still out on whether the joins will survive normal use over time... we'll see....
Small parts.  The Teflon bearings, bearing surfaces and other parts all installed well and work smoothly.   BUT.   The teeny screws, Phillips-style, were not robust enough to survive even moderate tightening before they stripped.  The metal was soft.  I had to replace all the screws with proper screws.  In Canada this means Robertson screw heads which are far less likely to strip....
And one last mention:  For some reason the Kit is supplied with NO installation or assembly manual.  I have never assembled a dob base before and had some head-scratching moments.  Inquiries to Dennis were answered promptly.  But why no instructions???
First light may be a while yet..... Snow on the ground....
Dave
#6 coopman
coopman
  • Loc: South Louisiana
Posted 14 January 2020 - 03:15 PM
Dennis does good work. Looks great.
Where did you get that black bar for the altitude encoder? My altitude bearings are similar to yours.
#7 Starman47
Starman47
  • Loc: Middle Tennessee
Posted 14 January 2020 - 03:23 PM
My experience with Dennis is that he is great. A few folks have had a problem here or there. That happens with anyone. But the real question is what happens after the problem. Dennis has always been great with his followup service.
I know it is too late for this now, but others may benefit from knowing that his links page on his website has assembly instructions.
http://dobstuff.com/links.htm
#8 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 03:34 PM
You mean in the second pic in post #3?
The 'black bar' and all encoder installation hardware  came with my kit right from DobStuff...
Dave
#9 junomike
junomike
  • Loc: Ontario
Posted 14 January 2020 - 03:36 PM
Looks good Dave.  I considered the same but found a 12" SW Base locally for cheap (and already assembled).
#10 airbleeder
airbleeder
  • Loc: Powder Springs, Georgia
Posted 14 January 2020 - 06:31 PM
   Looks great.
#11 a__l
a__l
Posted 14 January 2020 - 09:33 PM
Stick Velcro into place (red arrow). Stick another Velcro on the back of the Nexus DSC.
Bottom photo, my 14.5".
Edited by a__l, 14 January 2020 - 11:39 PM.
#12 Pinbout
Pinbout
Biscuit joints are great way to butt joint. It’s all you need.
#13 Cotts
Cotts
    Just Wondering
Posted 14 January 2020 - 11:53 PM
The kit did not come with biscuit joints.  You just screw one piece of plywood to another.  No fancy joinery....
Dave
#14 Cotts
Cotts
    Just Wondering
Posted 15 January 2020 - 12:00 AM
a_______l, I have velcro on the back of the Nexus box already since it is also used on my Discmount DM6.  However the "feet" on the Nexus box really interfere with its installation on the UTA of this Dob. (I've put a velcro strip on the UTA but it won't sit right....   I'm seriously considering removing the feet so that it will sit flat.  Grinder?  Knife??
Why on Earth did Serge put this beautiful piece of technology in such an oddly shaped box?  Makes no sense at all.....should just be a flat-sided rectangular box.
Dave
#15 a__l
a__l
Posted 15 January 2020 - 12:04 AM
Not. The feets remained. In my photo, they rest against the board. Hold well.
Top feets in the air (if I remember correctly).
Edited by a__l, 15 January 2020 - 12:07 AM.
#16 Dennis Steele
Dennis Steele
    vendor
  • Loc: Palm Desert, CA.
Posted 15 January 2020 - 01:34 PM
Hi all. When David first got the kit and asked if I had instruction -- a said I needed to post instructions the next time I built a rocker box for some. After I read David's post, and he pointed to my assemble a telescope webpage  I realized I really had the instructions out there already!! Thanks to David's comment, I took some of the photos and descriptions and created a "assemble a rocker box kit webpage".
Take a look at http://dobstuff.com/...BoxAssemble.htm and tell me what you think!!
(I hope this post fits into the forum guidelines. I thought it might. If not the moderator will know what to do!!) smile.gif smile.gif
Dennis
  • Pinbout likes this
#17 Pinbout
Pinbout
Posted 15 January 2020 - 09:05 PM
Nice pics
You use contact cement on alt bearings, don’t get the clamps... it’s suppose to be burnished on tongue2.gif
why not use same contact cement on the frp, more burnishing.
#18 Dennis Steele
Dennis Steele
    vendor
Posted 16 January 2020 - 01:27 AM
Yes, the clamps on the laminate. I found then unnecessary -- so an older picture. But, one way or the other it doesn't hurt to use 'em. It is true, though, the contact cement, if used correctly, will affix the laminate to the Baltic birch almost instantly!!
  • Starman47 likes this
