First M-1 Attempt
astrophotography beginner dslr
3 replies to this topic
#1 Blackbelt76
Blackbelt76
Posted 14 January 2020 - 10:32 PM
Would enjoy hearing from those with far more experience than myself what my next steps should be
or how I could improve this with the equip I'm using?
I'll eventually get into auto guiding, plate solving etc, though not til late spring
I've been unable to visually see M-1 thru my 9.25 Celestron; no doubt due to sky glow to my east.
Curious, I went out tonight, did a polar scope only alignment  to see if I could capture it.
I was pleased to say the least for my first attempt.
Focusing was difficult, but did the best I could using live view magnified and manually focusing.
Equip:
Nikon D300s APS-C, Un-moded
200mm f/2.8..Image shot at f/4, 90 secs unguided x10
No Flats used, only Lights, Darks and Bias.
Mount: Skywatcher EQ6R.
DSS to register and stack.
My post was all done in Adobe, though I know I have a long way to go here.
Primarily adjusted Levels, RGB curves, Noise reduction, Blend layer mask for hue/sat, unsharp mask.
I'm scaling the final image to increase it's size, though not sure if this is the best way?
Edited by Blackbelt76, 14 January 2020 - 10:39 PM.
  • Starman27 and Thaeland like this
#2 Gipht
Gipht
  • Loc: Prescott Valley, AZ.
Posted 14 January 2020 - 10:54 PM
There does not seem to be any color in the posted picture?    Maybe  something happened in the posting process?
Focus is one key in getting a better picture.  They do make Bahtinov masks for camera lenses.
M1 is a challenging target,  especially at a 200mm focal length.   M31, M42, or M45  are available this time of year and would be an easier place to start.
  • Thaeland likes this
#3 Blackbelt76
Blackbelt76
Posted 14 January 2020 - 11:01 PM
True; I didn't see any color in the original NEF image.
I don't know if I can capture color w/o a filter and un-moded DSLR?
Manually focusing a 200mm away from "so called" infinity is tricky.
My focus may have slipped during the evening; I probably should have placed a piece of tape on the focus ring. :)
#4 Gipht
Gipht
Posted 14 January 2020 - 11:17 PM
The stars should have some color with your camera even unmodified and without a filter.   Maybe try adding more color saturation?
Manually focusing a camera lens is tricky, and the correct focus can change as temperatures drop.  Sometimes the seeing is poor too, and that can  cause a blur.  The wider field looks fairly good focus wise.
  • Thaeland and Blackbelt76 like this
Also tagged with one or more of these keywords: astrophotography, beginner, dslr
