First Image (Horsehead + Flame) - Looking for feedback
17 replies to this topic
#1 Pedram
Pedram
  • Loc: Edmonton, Canada
Posted 15 January 2020 - 12:03 AM
Hey everyone!
This is the result of my first imaging session. I'm new to the hobby, and I followed veteran users' advice which was starting with Ha imaging for now. I took this from a white zone on the light pollution map (central Edmonton) with a 71% moon in the sky.  Total exposure was 2 hours (24 * 5min) guided. You can see the larger image here.
I'm still new to PixInsight and all I did in terms of processing was stretching, HDR Multiscale Tranform and ACDNR. Given that this is my first try, I'm very happy with the result. But, I noticed a couple of issues myself. Alnitak looks a bit weird, probably because of my processing. And it seems that my polar alignment was not accurate enough even though I did a drift alignment with PHD2. The stars are not perfectly round.
I'd love to hear your opinion. What could I do better? What can I work on for next time?
This is my equipment by the way:
SW Esprit 100ED
SW EQ6-R
ZWO 1600MM Pro
ZWO EFW
ZWO 36mm filters (LRGB + HOS)
Orion Mini 50 mm Guide Scope
Orion StarShoot AutoGuider
Best,
Pedram
  • Carol L, zjc26138, nofxrx and 19 others like this
#2 Kevin Ross
Kevin Ross
  • Loc: Traverse City, MI
Posted 15 January 2020 - 12:11 AM
Looks great! Congrats!
The pattern around Alnitak has nothing to do with your processing. It's the camera. The ASI1600MM Pro is known for it. It's one of that camera's biggest weaknesses. Just do what I do: fix it in Photoshop! :)
  • Swordfishy and Pedram like this
#3 bobzeq25
bobzeq25
Posted 15 January 2020 - 01:23 AM
That may be the best first image I've ever seen.  Seriously.
Alnitak is a unique problem.  Just ignore it for right now.
Polar alignment is best done with a small camera that does platesolving to locate the North Celestial Pole, and superimpose your mounts RA axis.  Way faster than drift, just as good for all practical purposes.  I have the $300 PoleMaster, very easy solution.  Only slightly harder is using Sharpcap Pro, and it's less costly.  No experience with it.
But those stars are good by me.  "Pixel peeping" will drive you crazy.
Do you have this book?
https://www.amazon.c...d/dp/0999470906
Edited by bobzeq25, 15 January 2020 - 01:26 AM.
  • Eric Horton, Aurneth, Swordfishy and 1 other like this
#4 Eric Horton
Eric Horton
Posted 15 January 2020 - 06:18 AM
Sharpcap is definitely the way to go. Very easy to use and the price is right. Due to a lack of drivers you may have a problem with the Orion camera on sharpcap. I finally had to upgrade because it just wouldn't work and finally stopped working in phd2.
  • Swordfishy, Huangdi and Pedram like this
#5 Mert
Mert
  • Loc: Spain, Pamplona
Posted 15 January 2020 - 08:45 AM
If that is your first real astro image then we are seeing a great imager rising up here! Congratulations with your first and impressive image here! Wish I would have started like you :waytogo:
#6 mic1970
mic1970
  • Loc: St. Louis Metro Area
Posted 15 January 2020 - 09:38 AM
Very nice.
  • Pedram likes this
#7 dhaval
dhaval
    Vendor
  • Loc: Round Rock, TX
Posted 15 January 2020 - 10:05 AM
That is excellent for a first image. I would not worry too much about the stars, just yet, you will need to get better at Polar Alignment and Guiding, but those can wait.
From a processing standpoint, here's hopefully some constructive feedback - I think you are clipping the black point minimally, but definitely. The background is a bit too dark - this region is exceptionally bright with prominent Ha. I would go back and re-do the stretching a bit and you will be able to bring out more structure to the Ha regions.
CS!
#8 Pedram
Pedram
Posted 15 January 2020 - 11:03 AM
The pattern around Alnitak has nothing to do with your processing. It's the camera. The ASI1600MM Pro is known for it. It's one of that camera's biggest weaknesses. Just do what I do: fix it in Photoshop! smile.gif
Thank you! I had no idea about this. I was sure I'm doing something wrong laugh.gif
Thank you very much!
Good to know about Alnitak. I'll search the forum and read more about it.
About polar alignment, unfortunately, I shoot from balcony in a south-facing apartment. I have a fairly wide view (140 to 150 degrees), but I don't see west and east horizons which makes even drift alignment challenging.
I need a view of Polaris for Sharpcap, right? I explained above, I cannot see Polaris from my balcony :(
If that is your first real astro image then we are seeing a great imager rising up here! Congratulations with your first and impressive image here! Wish I would have started like you waytogo.gif
This maybe the best compliment I've ever received. Thank you very much :)
Very nice.
Thank you :)
CS!
Thank you. Since I don't have a view of Polaris, and my east and west horizons are blocked (15 to 20 degrees each) polar alignment is a bit challenging. I'll definitely spend more time on it next time.
Thanks for your feedback. I really appreciate it. I had the same feeling, but Alnitak getting more weird was stopping me from making it brighter. I thought I'm overdoing it. But based on other comments, it seems that I shouldn't worry about that for now.
  • Swordfishy likes this
#9 Pedram
Pedram
Posted 15 January 2020 - 11:57 AM
Perhaps I should say this is my first image ever. I shot it with my stock 40D without any filters or anything before my ZWO camera arrived. 1 hour exposure (60 * 1min). I had a hard time dealing with LP and the image didn't end up great. Probably the sub exposures were too long.
  • F.Meiresonne, kisstek, Swordfishy and 1 other like this
#10 TelescopeGreg
TelescopeGreg
  • Loc: Auburn, California, USA
Posted 15 January 2020 - 02:33 PM
Wow.
Why bother with the ASI?  You're getting great results with the DSLR.
#11 lynnelkriver
lynnelkriver
  • Loc: Elk River, Mn.
Posted 15 January 2020 - 02:37 PM
Great first image!  Scott
#12 Pedram
Pedram
Posted 16 January 2020 - 12:16 AM
Wow.
Haha thank you. Light pollution is brutal here. I had a hard time processing the DSLR image and it ended up looking cartoonish.
Thank you, Scott :)
#13 BobNY
BobNY
  • Loc: Long Island, NY
Posted 16 January 2020 - 11:10 PM
Wow, those are great! Looking forward to you 3rd, 4th and beyond.
#14 Swordfishy
Swordfishy
  • Loc: Miami, FL
Posted 17 January 2020 - 11:35 AM
Ditto! This is great. Ha is AMAZING aint it?
 Love your attempt! Looking forward to more.
 Pixinsight is easy to pick up if you try, but then incredibly complex! I love it because we can continue to go back, start afresh with old data and get completely different results as we improve in skill. It is like Magic!
 Keep it up!
  • bobzeq25 likes this
#15 bigeastro
bigeastro
  • Loc: Southwest Florida
Posted 18 January 2020 - 11:37 AM
Hey Pedran,
I only have one comment.
Super nice Horsehead image.   Wonderful.
Enjoy!
#16 ConnorM
ConnorM
Posted 19 January 2020 - 11:24 AM
Amazing job. I live in the South of Edmonton and deal with loads of LED pollution from the Henday.
It is good to see such amazing work from the inner city.
That looks pretty good for such a low exposure time.  I feel with additional exposure time you could help resolve some of the noise in the image background.
I noticed the stars have a bit of shape to them as well, It is hard to see if that is from the mount/guiding or polar alignment issues.
Edited by ConnorM, 19 January 2020 - 11:29 AM.
#17 sunnyday
sunnyday
  • Loc: Ottawa,Canada
Posted 19 January 2020 - 11:34 AM
really pretty,nice work
#18 Pedram
Pedram
Posted 22 January 2020 - 04:21 PM
 Keep it up!
Thank you! Ha is wonderful!
I've started using PixInsight. The UX is horrible, but I can see how poweful it is.
Hey Pedran,
Enjoy!
Thanks so much :)
Thank you.
I really appreciate your feedback. That makes sense. I'll go back horsehead it for a longer exposure for sure. I was trying to test everything and see how things work out. Next time, I'll plan for a longer exposure.
I definitely need to work on guiding/alignment. My limited view makes polar alignment a bit challenging. If we get a clear night, I can give it another try and hopefully improve it.
Thank you :)
