RASA 8 Collimation help
1 reply to this topic
#1 hebar
hebar
  • Loc: Florida
Posted 15 January 2020 - 12:16 AM
Hello All!
My images showed tight stars in the center and elongated stars with different directions in the corners with two different cameras (asi1600 and asi183). I know for a fact the ASI1600 does not have tilt. Using ccdinspector it showed tilt so I believe it is out of collimation.
Using a defocused Star I attenpted to collimatate the scope. The inner most ring was slightly off-center favoring the left side so that confirmed it was slightly out of collimation. As I turned the push/pull adjustment screws by 1/2 to a full turn I barely saw the inner ring move. I kind of got lost with how much I turned each screw because i was not seeing much change.
For those that have attempted collimating their RASA. How sensitive was each adjustment? Did you have to loosen/tighten the screws a lot to see noticable change in collimation? Do you have a better strategy than what the manual says?
Clear skies! Thanks!
#2 bobzeq25
bobzeq25
Posted 15 January 2020 - 01:30 AM
Hello All!
I have a C8 RASA.  Haven't collimated it, sorry.  But this may help.
Started out with a similar problem with stars.  So bad they were donuts at the edge sometimes.  The tilt was not in collimation or the camera, it was in the Celestron adapter and/or my spacer.  Fixed it with a one piece PreciseParts adapter that replaced both.  Here's the result and more info.
https://www.cloudyni...sis-pp-adaptor/
You'd want this.
https://celestron-si...dapter_Rev1.pdf
Final image.  Click on it for acquisition details.
https://www.astrobin.../full/025umc/C/
Edited by bobzeq25, 15 January 2020 - 01:53 AM.
