120mm Refractor mount, which ra motor to use?
5 replies to this topic
#1 petersmeadelx6
petersmeadelx6
  • Loc: Beeton, Ontario
Posted 15 January 2020 - 08:23 AM
I thought I had posted this question a week ago but can't seem to find it so it may not have stuck OR I may have placed in the wrong discussion group. For that, I apologize.
So, the question is:
I have purchased a 120mm refactor (Newstar/Synta I expect) and it is on a fairly sturdy mount. I would like to add a R.A motor but am not certain which brand-type I should be looking into. Picture of mount, motor mounting area attached.
I currently have the 120 mounted on an Ioptron cube (a bit beyond the Cube's limit but does work) and would like to remount on the EQ with a RA motor for some tracking and camera work.
Any suggestions?
Thanks in advance and happy viewing.
#2 petersmeadelx6
petersmeadelx6
Posted 15 January 2020 - 08:24 AM
And if you are relatively local and have an appropriate motor, let me know.
#3 Eddgie
Eddgie
Posted 15 January 2020 - 09:08 AM
I recommend that you post a wanted ad in the CN Classifieds.
  • 25585 likes this
#4 Rutilus
Rutilus
Posted 15 January 2020 - 09:15 AM
The mount you have is a Sky-watcher EQ5.  I have the same mount with my 120mm f/8.3 refractor.
Google: Skywatcher R.A. Motor Drive For EQ5 Mount.
#5 tog
tog
  • Loc: Front Yard
Posted 15 January 2020 - 10:13 AM
It also looks like Orion's SkyView pro mount. You might ask them if their True track drive will work.
#6 petersmeadelx6
petersmeadelx6
Posted 15 January 2020 - 11:30 AM
Thank you for you help. I had no idea what to ask for which is why I did not post in the wanted section. I will do so now as the request won't be so ambiguous.
Have any of you used the Simple Dream EQ5 unit I see advertised in Cloudynights?
