Canon t3i subs more than 30 sec?
17 replies to this topic
#1 astrojaiphotography
astrojaiphotography
  • Loc: Colorado Springs, CO
Posted 15 January 2020 - 09:19 PM
I'm getting to that point in AP where subs longer than 30 seconds are needed. I have a mount capable of tracking accurate enough for this. The longest captures I can take with the t3i are thirty seconds, then it jumps to bulb mode. I use the intervalometer in Magic Lantern. I want to be able to take longer exposures while still being in the intervalometer mode. Help?
  • Thaeland likes this
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 15 January 2020 - 09:47 PM
You can buy an external intervalometer which can take longer exposures.
#3 astrojaiphotography
astrojaiphotography
Posted 15 January 2020 - 09:49 PM
Which intervalometer?
#4 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 15 January 2020 - 09:51 PM
Canon sells external intervalometer.  You can also buy aftermarket ones.  I use BackyardEOS.
  • Greyhaven and guyroch like this
#5 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 15 January 2020 - 10:11 PM
Magic lantern will work too. If it’s the same as the t2i, set the top dial on the camera to M for manual. Then go into the magic lantern menu under “shoot” and enable intervalometer. After enabled, it gives you some more options in another menu. The only thing in the intervalometer menu that is maybe not straight forward is the “take a pic every __” setting. That needs to be set at whatever amount of time your subs will be plus a few seconds.
Then enable  “bulb timer” also under the “shoot” menu and set it for the length you want your exposures to be.
Edit: the camera itself also needs to be set on bulb.
Edited by Daveatvt01, 16 January 2020 - 11:38 AM.
#6 BQ Octantis
BQ Octantis
  • Loc: Red Centre, Oz
Posted 16 January 2020 - 05:32 AM
I use this one for my T3i without issue:
https://www.amazon.c...uct/B003Q9RERY/
But I use it because I didn't want to install Magic Lantern… scratchhead2.gif
BQ
#7 kevinbreen
kevinbreen
  • Loc: Wexford, Ireland
Posted 16 January 2020 - 11:13 AM
BQ
I have the exact same one as this. But there's something strange happening. I have LONG set to 40 seconds, INTERVAL set to 10, N set to 100, sound on. Camera is in MANUAL and BULB.
The problem is the exposures are only 25 seconds, or something like that. I can't figure it out. Anyone got any advice??
#8 StarBurger
StarBurger
  • Loc: North Country NY
Posted 16 January 2020 - 12:38 PM
Kev, looks like you have the 'ometer set right. Also ensure the DELAY is 0.
Maybe  check the mirror lock up function is off. When I tried to use it the double/bulb shutter press did not work as expected and the exposure was shortened and would not repeat.
#9 kevinbreen
kevinbreen
Posted 16 January 2020 - 03:19 PM
Thanks Starburger. I think you're right, mirror lock. I'll check it later.
Sorry to hijack the thread BTW!
#10 calypsob
calypsob
Posted 16 January 2020 - 07:14 PM
Get magic lantern, it is so much better than having to carry around an intervalometer and an extra set of batteries.
It offers many other benefits as well, fps over ride, live view gain control, etc.  Their intervalometer is really easy to use. I have been using ML on 3 cameras for 10 years, its a piece of cake to use and really easy to install. Do follow the instructions.
#11 sabersix
sabersix
  • Loc: Midway GA
Posted 16 January 2020 - 07:33 PM
Astrophotography tools is a free download and can help you out.
#12 Kendahl
Kendahl
  • Loc: Pinedale, Arizona
Posted 16 January 2020 - 10:09 PM
The T3i has no setting for exposures longer than 30 seconds. You have three options to go longer:
  • An intervalometer.
  • A camera control program that runs on a computer. Canon's EOS remote control utility works. Other programs (e.g. Backyard EOS) are designed for astrophotography.
  • Set the camera to Bulb and use a cable release.
#13 kevinbreen
kevinbreen
Posted 17 January 2020 - 10:56 AM
Actually,it was nothing to do with mirror lock it turns out. I had the Canon set to remote control and that was screwing it up for me. Another lesson learnt!
#14 BQ Octantis
BQ Octantis
Posted 17 January 2020 - 05:05 PM
Figures. I would have guessed the 10 second timer.
#15 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 17 January 2020 - 06:21 PM
A fourth option is magic lantern, which the OP says they have already. It adds many functions to canon cameras, like an intervalometer.
#16 astrojaiphotography
astrojaiphotography
Posted 17 January 2020 - 08:47 PM
Thanks Daveatvt01! This works for me with ML: put camera on bulb mode. Then, set the bulb timer in ML to your exposure length. Then, enable the intervalometer and set the number of desired photos. Set the time between photos to the desired exposure length plus a few seconds. Then, change the setting of when to start the intervalometer to when you leave the ML menu. Now, you can use bulb timer and intervalometer together.
ML: Magic Lantern
#17 Daveatvt01
Daveatvt01
  • Loc: Tucson, Az
Posted 17 January 2020 - 09:31 PM
Glad you got it working!
#18 Domtbol
Domtbol
Posted Today, 03:55 PM
I use "DSLR Controller"  , Its a paid app for Android and IOS. I use it on a canon 550D and 600D with a usb cable but it can also be used via wifi .  It only works on Canon EOS.
