Denver Observing Chair --- NW Edition
3 replies to this topic
#1 whizbang
whizbang
  • Loc: NE of Seattle, WA
Posted 16 January 2020 - 03:23 PM
My winter time project was a "Denver Observing Chair".  I made a few modifications on the design:
1) I used a small lid support hinge instead of the customary aluminum bar spreader.
2) To keep the seat in position, there is a row of screws and 1/4-20 nuts installed on the back side of the front leg.
3) The top, bottom, and cross support ends are all tapered approx. 20 degrees.
4) The cross support is attached to the back leg when it is less likely to trip you up in the dark.
5) A small nose/foot is attached to the bottom of the front leg as a seat stop, and, to move the center of gravity slightly forward.
  • payner, dryfly, havasman and 4 others like this
#2 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 16 January 2020 - 06:09 PM
Very nice.,can you show us the bottom of the seat?.,cheers.,
#3 coopman
coopman
  • Loc: South Louisiana
Posted 16 January 2020 - 06:26 PM
Looks good, but the seat isn't horizontal to the ground is it?
#4 whizbang
whizbang
Posted 17 January 2020 - 01:21 AM
The seat started out tilted slightly up.  The corner edge of the 2x4 seat support block rests on the front leg.  As I worked on the chair and tested the chair, the block edge has worn so the seat tilts slightly down.
I haven't decided if I an going to cut a triangle shaped wedge for the end of the seat block, or re-cut a new block with a tapered end that butts flush to the leg.
The original Denver Observing chair relied on the square block edge to bite into the non-skid material to keep the seat from sliding.  This design does away with the non-skid, and, uses screws and washers instead.  So, the seat block can be flush with the leg rather than bite into the leg.
Edited by whizbang, 17 January 2020 - 01:23 AM.
