QHY695A - problem
6 replies to this topic
#1 Tayson82
Tayson82
  • Loc: Poland / Wolomin
Posted 17 January 2020 - 06:33 AM
Hi.
I need some quick help.
When I connect my camera to MaximDL6, after few subrames (3, 5 or 7) camera can't download file. First few subframe download correctly. I cheeck from 3 to20minutes subframe and length does not matter.
The same issiue is with EZCap.
Very strange is that camera catch darks without any problems! Only on lights at the nights I have got problems.
Afert this I usualy have to power off and power on camera, becouse windows don't see device.
Also I bought new pc and problem not disapered.
My astro pc in own backyard obserwatory:
- win7,
- camera connected directly to pc (usb2.0) by new 2m good quality cable,
- everything powered from very goog quality power supply 13,5V,
- qhy695A have all newest driver
- installed last version ascom
Thank you for all suggestions.
Edited by Tayson82, 17 January 2020 - 06:50 AM.
#2 cccha
cccha
Posted 18 January 2020 - 09:44 PM
I think you can contact QHYCCD technicians by email (cha@qhyccd.com) and let them provide help remotely,
#3 Jared
Jared
  • Loc: Piedmont, California, U.S.
Posted 18 January 2020 - 10:02 PM
I wonder whether it is somehow temperature dependent—ambient temperature, that is.  It’s the only thing I can think of that is different between a light frame and a dark. You are probably taking darks indoors at room temperature, but lights are outside in the cold. Could the camera or the computer be having communication issues when it gets cold?  Or even the cable?  Since you have already bought a new computer, I would try a new cable just because cables sometimes cause intermittent issues like this.  I would also contact QHY.
Edited by Jared, 18 January 2020 - 10:03 PM.
#4 cccha
cccha
Posted 19 January 2020 - 04:28 AM
What's your ambient temperature? I think the outdoor temperature has little effect because the freezing camera has a strong adaptability to the ambient temperature. As for the cable, I think there will be many situations that affect the stability of the camera. The length of the cable should not be too long. Otherwise, an extension cable with an external power supply needs to be added.
#5 Tayson82
Tayson82
Posted 19 January 2020 - 06:06 AM
Outdoor from - 1 to +4C. I tryed few usb cables and no positive results.
#6 cccha
cccha
Posted 20 January 2020 - 12:53 AM
Understand, I need to find the cause of the problem remotely. Can you tell me your email address or contact cha@qhyccd.com?
#7 Tayson82
Tayson82
Posted 29 January 2020 - 03:59 AM
Problem solved.
In this case usb hub was guilty.
