Fan voltage question
4 replies to this topic
#1 Alvin435
Alvin435
Posted 18 January 2020 - 02:01 PM
Hi, I have a Orion fan that runs on 8 D batteries. Can it run off 12 volts and if it can is there potentially anything I need to be aware of. Thanks Alvin
#2 scadvice
scadvice
  • Loc: Lodi, California
Posted 18 January 2020 - 02:07 PM
DC 12 volts will work fine as long as the D cells were in series which is very likely. Look on the fan housing as it should tell the voltage requirement.
#3 SteveG
SteveG
  • Loc: Seattle, WA
Posted 18 January 2020 - 02:28 PM
8 x 1.5 = 12, so yes. Most of those fans will work with between 6-12v DC.
#4 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 18 January 2020 - 02:30 PM
Not critical.
These DC fans will usually start reliably at around 5V, and are certainly OK to 15V at least. So you can use on a car-powered setup as well.
Fan speed will vary with voltage. I run mine at 12V for pre-cooling, then I step down to 8V during observing for less noise & no vibration.  Simple LM7808 circuit will accomplish that trick.
CS
Bob
  • SteveG likes this
#5 Alvin435
Alvin435
Posted 18 January 2020 - 02:36 PM
Thanks greatly appreciated
