Barlow Connection with NexstarSE
astrophotography beginner Celestron
5 replies to this topic
#1 cman2187
cman2187
Posted 19 January 2020 - 01:09 AM
Hi. Noob here, so be gentle.
I am trying to figure out how to use a Barlow's magnification with a DSLR (Nikon D3200) on a Celestron Nexstar 4SE scope.  I have the t-ring and adapter (Celestron model 93635-A) hooked successfully to the scope and am actually getting decent pictures. What I want to do is hook up a Barlow lens to the camera and get some better magnification/resolution.
Is this possible?  My google-fu is weak in this regard.
#2 james7ca
james7ca
  • Loc: San Diego, CA
Posted 19 January 2020 - 01:44 AM
It can be hard to find an all-threaded connection when it comes to barlows. The easiest solution would be to use the visual back and place the 1.25" barlow in that and follow that with a 1.25"-to-T-thread adapter and then on to your Nikon with its own T-thread adapter.
So, something like the following:
<Celestron Visual Back> <1.25" barlow> < 1.25"-to-T-thread adapter> < T-thread adapter for the Nikon> <Nikon camera mount>
And these would mate as follows: female(Visual Back slip-fit output) male(1.25" balow slip-fit input) female(1.25" barlow slip-fit output) male (1.25"-to-T-thread adapter slip-fit input) male(1.25"-to-T-thread adapter output threads) female(Nikon T-thread adapter input threads).
Other than the 1.25" barlow the only part you will need is: https://agenaastro.c...-t-adapter.html
[UPDATE]
Actually, on the 4SE it would be easier just to place the barlow in the right-angle viewing port as a "visual back" really isn't part of the standard 4SE configuration. So, it would be as shown above once the barlow is inserted into the standard 1.25" eyepiece holder.
Or, I guess you could add a 1.25" eyepiece holder to the 4SE's photographic port and avoid going through the flip mirror, but that would cost more than just using the existing eyepiece port.
[/UPDATE]
Edited by james7ca, 19 January 2020 - 05:48 AM.
#3 cman2187
cman2187
Posted 19 January 2020 - 10:09 AM
Thank you james! I'm not necessarily looking for an all-threaded connection, just a way to get a barlow onto my current setup (example in linked images here https://cdn.shopify....pg?v=1529943582
So from what you're saying, I think what I need is 1) a 1.25" adapter to thread onto the photo port, and 2) a 1.25" Barlow lens.  Would the piece you linked work for the photo port adapter? And would any 1.25 barlow work (questions of quality and price aside)? Or do I have it all crabbed?
Edited by cman2187, 19 January 2020 - 10:16 AM.
#4 james7ca
james7ca
Posted 19 January 2020 - 10:16 AM
You don't really need to add the 1.25" eyepiece adapter for the 4SE. You can just use the standard 1.25" eyepiece holder that goes through the flip mirror. However, I guess if you added an eyepiece holder to the photographic port you could flip between your regular eyepiece and the view through the camera. That might be useful as a kind of finder scope.
However, in either case what you do need is the 1.25"-to-T-thread adapter that I linked earlier.
#5 cman2187
cman2187
Posted 19 January 2020 - 11:10 AM
Thanks for your patience in this; my newness is showing.
So just to be crystal clear, the adapter you linked is supposed to thread into the Nikon t-ring, and would sit in between the barlow and the scope.
Did i get that right?
#6 james7ca
james7ca
Posted 19 January 2020 - 06:23 PM
Yes, that's right. One end of the adapter screws into the female threads on the Nikon's T-Ring. Then, the other end of the new part just slips into the 1.25" female end of the barlow. The link I provided has additional descriptions on how to use this part. Also, you don't need to get it from Agena Astro. Similar parts are sold by most astro-focused retailers, and probably on Amazon.
Edited by james7ca, 19 January 2020 - 06:26 PM.
  • cman2187 likes this
Also tagged with one or more of these keywords: astrophotography, beginner, Celestron
