Adding an OAG to Imaging Train w Feathertouch Focuser (SCT)
2 replies to this topic
#1 techmgr
techmgr
  • Loc: North Central Ohio
Posted 19 January 2020 - 01:10 AM
I have a Celestron C-11 to which I've added a Feathertouch Crayford focuser.  Up to now I've use a separate guidescope setup for guiding, but I would like to switch to using an OAG (looking at the Celestron OAG).  I'm having a hard time trying to determine whether I will be able to put this into the imaging train between the focuser and the camera setup or not.  I'm sure this sounds like a stupid question, but is it possible? Does the OAG come with an adapter to add it to the focuser?
Thanks in advance for any help you can provide.
#2 futuneral
futuneral
  • Loc: Phoenix, AZ
Posted 19 January 2020 - 01:52 AM
That's actually how it's supposed to be used. Any specific issues you're seeing with this?
Check this out:
https://www.cloudyni...hy-setup-guide/
  • elwaine likes this
#3 DuncanM
DuncanM
  • Loc: Arizona Sky Village or the rain forest
Posted 19 January 2020 - 02:09 AM
Most OAG's will come with a 2in barrel adapter:
Crayford->2in barrel adapter-OAG->spacers->Tring->camera
or some variation of the above.
If you are going to use a focal reducer, I'd suggest looking at the Starizona .63x SCT FR,  which should work well with a C-11 'classic' as it has a 2in barrel.
In which case the setup would be:
Crayford->SCT FR->t adapter->OAG->spacer->Tring-camera. If you tell Starizona which focuser and OAG you have, they will make sure you get the right spacers.
Edited by DuncanM, 19 January 2020 - 04:16 AM.
