PI Bias integration settings?
2 replies to this topic
#1 calypsob
calypsob
Posted 19 January 2020 - 11:09 AM
Im creating a master bias for my A7RIII in Pixinsight and have not done this in a long time.
Im using this site for a baseline process http://dslr-astropho...as-frames-dslr/
My question here is what should I use as a scale estimator?
What type of pixel rejection should I use?  Im stacking 450 subs. I typically prefer to using the linear regression rejection algorithm
Finally, how do I analyze my bias frame to ensure it is optimal?
Should I use ROI and restack in pursuit of some objective?  thanks
#2 bobzeq25
bobzeq25
Posted 19 January 2020 - 11:22 AM
Personally, I do this very simply.  The defaults, except for changing to "no normalization" and "all weights=1", and adding the desired rejection algorithm.  I use linear fit, others work well also, depending on how many bias exposures you have.  It's mostly a personal choice.
450 bias exposures is excellent, that's important.  You can use whatever rejection algorithm you want, although people would generally use one of the more elaborate ones.
Generally people who want to check just stretch the bias, and examine it visually for issues.  Often they just ignore that step.
Edited by bobzeq25, 19 January 2020 - 11:26 AM.
  • calypsob likes this
#3 georgian82
georgian82
  • Loc: Healdsburg, California
Posted 19 January 2020 - 11:28 AM
I have followed this tutorial in the past with very good results:
https://www.lightvor...pixinsight.html
Edited by georgian82, 19 January 2020 - 11:29 AM.
  • jerahian likes this
