64 bit downloads.
6 replies to this topic
#1 arrowspace90
arrowspace90
  • Loc: United States
Posted 19 January 2020 - 01:24 PM
The laptop I dug up out of a closet to use for AP software is an old Toshiba Satellite that is 6 or 7 years old.
So old, I just thought it must be a 32bit when I went to download ASCOM platform and other stuff.
But checking the specs, Windows 8, it says it is in fact 64bit.
Should I delete my programs and redownload?  How much of a difference does it make?  Will the programs just run slow or work at all?
#2 Cali
Cali
  • Loc: Bay Area
Posted 19 January 2020 - 01:49 PM
32-bit software is going away. Might want to go after the 64-bit rev. now. With time, you're gonna end up there anyway.
- Cal
Edited by Cali, 19 January 2020 - 01:50 PM.
#3 arrowspace90
arrowspace90
Posted 19 January 2020 - 01:58 PM
- Cal
Thanks.  I will delete and re-download.  I will likely succeed in messing up EQMOD, which was a trial to get running.
#4 Cali
Cali
  • Loc: Bay Area
Posted 19 January 2020 - 02:02 PM
Might be a good time to move to Windows 10.
I'd max out the memory too.
- Cal
Edited by Cali, 19 January 2020 - 02:54 PM.
#5 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 19 January 2020 - 02:26 PM
No need to do anything to the laptop. ASCOM  will work fine on the computer, just make sure that you have all of the necessary C++ run time libraries. The download will tell you what's going on. I wouldn't bother to pay any money to upgrade that box unless there is some other reason to do so. Pretty much any laptop makes a fine imaging system.
Rgrds-Ross
#6 MikiSJ
MikiSJ
  • Loc: San Jose, CA
Posted 19 January 2020 - 03:33 PM
If your laptop is only as old as you say it is - then is very likely a x64bit machine.
Windows 8/10 has the capability to run 32 bit programs and there is a utility that allows you to run in 'Compatibility Mode'.
  • arrowspace90 likes this
#7 arrowspace90
arrowspace90
Posted 20 January 2020 - 02:00 PM
Hopefully, I'm ok.  The ASCOM platform was 64 bit.  For NINA, I downloaded 64 bit.  SharpCap is 32.  ASTEP plate solver is 64.
