William Optics EX Touch mount options - dual vs single ?
2 replies to this topic
#1 vkhastro1
vkhastro1
  • Loc: Vankleek Hill, Ontario, Canada
Posted 20 January 2020 - 10:09 AM
I have an original William Optics (AOK Swiss) silver coloured Alt-Az mount
It presently has the Vixen style saddle on one side.
The opposite side has a threaded counterweight bar with counterweights (several various sizes available).
The opposite side has two threaded holes (35mm apart) that can also accept a dovetail saddle.
The mount is located on an Oberwerk wooden tripod with extendable legs.
Is it worth-while to buy an extra dovetail saddle (thinking a dual - Losmandy/Vixen version) ?
How easy is the balancing for a dual scope option (one scope on each side) ?
Can the original Vixen style dovetail saddle be removed (to be upgraded to a dual saddle) since no removable mounting screws are present ?
Edited by vkhastro1, 20 January 2020 - 10:17 AM.
  • timmbottoni likes this
#2 junomike
junomike
  • Loc: Ontario
Posted 20 January 2020 - 01:55 PM
Gary, I had that same mount for several years.
I used it in dual mode but perfect alignment was impossible due to flex (cone error) and even equaling the Alt for both.
I got around this by using a secondary OTA with double the FOV than the primary OTA. Then I centered objects with the primary and it was
still visible in the secondary saddle OTA.
Never had an issue balancing although if you're out by a large amount the clutches won't hold.
This was one mount were I valued the TV Equalizer as I used it for the Delos and the switching to the 31T5 (or similar) made for close enough/equal weight.
Without it the OTA needed to be rebalanced.
The OEM vixen saddle + axel is machined from one peice thus not changable.
I used a Vixen to Losmandy adapter a few times to make it compatible with the Losmandy Saddle .
#3 timmbottoni
timmbottoni
  • Loc: W Chicago suburbs, IL USA
Posted 20 January 2020 - 08:26 PM
I have had mine set up to use as a dual mount for various applications.  It's a bit tricky to get them perfectly aligned, but getting them close enough isn't hard at all.  I have done it with my WO FD80 and C8 at the same time, and I have used it for events like the Total Eclipse as shown in this Z61 review post.
The rotation is adjusted by loosening the small metric set allen set screws.
https://www.cloudyni...utions-welcome/
