Any ALT/AZ CPC type 12-14" SCT Scopes in the works?
2 replies to this topic
#1 Procyon
Procyon
  • Loc: Eastern Canada
Posted 20 January 2020 - 12:37 PM
Or just wishful thinking?
#2 junomike
junomike
  • Loc: Ontario
Posted 20 January 2020 - 01:40 PM
Only Meade currently available..  Celestron only does the 11" max as that's most people will be able to handle.
#3 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 20 January 2020 - 04:24 PM
The CPC-11” is quite a hefty lift and I’ve also tried a Meade LX200 12” - it’s too big and heavy to lift safely in one piece - you’re quite likely to injomire your back or damage the scope. And I’m 196cm and quite strong. A lot of these end up being de-forked partly because of the weight and also because the mounts failed one way or another.
in this respect there is some sense in separating an OTA that may last 15–20 years or more from the mount, which is likely to have a life of 10 years or so, limited either by failure, or the desire to upgrade to something more technologically advanced.
If you look at gear from 20-30 years ago an awful lot has changed in mounts, and it will continue.
Edited by luxo II, 20 January 2020 - 04:25 PM.
