First Attempt at Sketching (M42 and M43)
13 replies to this topic
#1 WolfFang
WolfFang
  • Loc: Southern New York
Posted 21 January 2020 - 10:20 AM
Hi everyone!
After getting a new AD10 for Christmas (had a One Sky before that) I decided to try sketching! The desire to see the Orion Nebula was the original impetus for getting into telescopes in the first place so I figured it was a good place to start! I will have to invest in a better light though because my only red light is very bright and holding it while also juggling a clip board and pencils/tools was difficult. Any suggestions?
Date: 1/20/20
Time: 6:45pm
Instrument: AD10
Aperture: 254mm
Focal Length: 1250mm
Eyepiece: Orion Expanse 9mm
Filter: Orion Ultrablock
Conditions: Clear, Very Cold
  • frank5817, Mel Bartels, Tanglebones and 19 others like this
#2 niteskystargazer
Posted 21 January 2020 - 10:44 AM
Welcome to CN .
Very nice  First Attempt at Sketching (M-42 and M-43) smile.gif .
thanx.gif ,
  • WolfFang likes this
#3 WolfFang
WolfFang
Posted 21 January 2020 - 11:13 AM
Thanks Tom!!
#4 perfessor
perfessor
  • Loc: Northern Illinois
Posted 21 January 2020 - 11:32 AM
That is a very nice sketch, never mind it being a first sketch.  Lots of fine detail.
You ask for advice, I have a few:
1. Invest in a suitable table.  It doesn't have to be much - a small folding table at the local big box cost me about $20.
2. Lighting - Lots of people have lots of different solutions.  My first success was a clip-on book light (look for these at Barnes and Nobles or the like), with the lamp covered in red transparent tape.  You may have to get creative.
3. Maybe try a lower power eyepiece? Something around 25 to 30 mm will brighten diffuse targets and put more of it in the field of view.
4. Keep at it! You are off to a great start, and I look forward to seeing more of your efforts.
Cheers!
#5 frank5817
  • Loc: Arizona
Posted 21 January 2020 - 11:34 AM
WolfFang,
Welcome and you arrive bring a gift. Excellent sketch of M42/43.
You need to get the red flashlight out of your hand. Perhaps a clip-on to the clipboard.
I use this one which works well. I got it at a book store.
#6 WolfFang
WolfFang
Posted 21 January 2020 - 01:09 PM
Thanks! I'll have to get one of those clip on lights! Follow up question (I hope you don't mind!) what is the scale everyone is using here for seeing. I've seen stuff like 2A and I can't find what that means anywhere
#7 frank5817
  • Loc: Arizona
Posted 21 January 2020 - 01:51 PM
That would be the Pickering scale. It goes from 1-10.
https://www.skyandte...cale-of-seeing/
1 — Star image is usually about twice the diameter of the third diffraction ring if the ring could be seen; star image 13 arcseconds (13") in diameter.
2 — Image occasionally twice the diameter of the third ring (13").
3 — Image about the same diameter as the third ring (6.7"), and brighter at the center.
4 — The central Airy diffraction disk often visible; arcs of diffraction rings sometimes seen on brighter stars.
5 — Airy disk always visible; arcs frequently seen on brighter stars.
6 — Airy disk always visible; short arcs constantly seen.
7 — Disk sometimes sharply defined; diffraction rings seen as long arcs or complete circles.
8 — Disk always sharply defined; rings seen as long arcs or complete circles, but always in motion.
9 — The inner diffraction ring is stationary. Outer rings momentarily stationary.
10 — The complete diffraction pattern is stationary.
Another scale frequently used is the Antoniadi Scale
1. (I.) Perfect seeing, without a quiver.
2. (II.) Slight quivering of the image with moments of calm lasting several seconds.
3. (III.) Moderate seeing with larger air tremors that blur the image.
4. (IV.) Poor seeing, constant troublesome undulations of the image.
5. (V.) Very bad seeing, hardly stable enough to allow a rough sketch to be made.
Note that the scale is usually indicated by use of a Roman numeral or an ordinary number.
  • jlcop and WolfFang like this
#8 perfessor
perfessor
Posted 21 January 2020 - 01:59 PM
BTW Wolffang - you might want to alter your profile to show your location.  This may help us in conversations about weather, seeing, outdoor gear, etc.  :)
#9 sunnyday
sunnyday
  • Loc: Ottawa,Canada
Posted 21 January 2020 - 02:03 PM
nice debut
well done
#10 Jef De Wit
Jef De Wit
  • Loc: Hove, Belgium
Posted 21 January 2020 - 02:27 PM
This is a great first sketch!
#11 WolfFang
WolfFang
Posted 21 January 2020 - 03:05 PM
Thanks for all of the support everyone! It means so much!
Frank - I will be sure to make note of that scale from now on when I'm out. Thanks!
perfessor - Adding location now. Thanks for the heads up!
  • perfessor likes this
#12 GUS.K
GUS.K
  • Loc: Katoomba, NSW, Australia.
Posted 21 January 2020 - 03:12 PM
Really nice sketch WolfFang.
#13 DDEV
DDEV
  • Loc: Dublin, Ireland
Posted 22 January 2020 - 08:08 AM
Hi there,
Impressive sketch of M42, regardless of whether it was your first or 100th sketch... Keep them coming!
Clear skies,
Darren.
#14 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 24 January 2020 - 06:43 AM
You grabbed a lot of detail for a first sketch. Very nice. You picked a tough one to sketch. :)
