Having a problem with the Omegon Mount Mini Track LX3
astrophotography beginner equipment
1 reply to this topic
#1 vedran_kristina
vedran_kristina
Posted 22 January 2020 - 07:17 AM
Hi everyone!
I recently bought the Omegon Mount Mini Track LX3, mounted my Sony A6000 (18-135mm) on it and pointed it at Polaris. No matter what spring tension setting I use, I start to get star trailing after a couple of seconds of exposure when zoomed in. Does anybody have any experience with the Mini Track and some suggestions what am I doing wrong?
Thank you!
#2 Seven007
Seven007
  • Loc: Germany
Posted 26 February 2020 - 11:23 AM
Hi Kristina,
I have Minitrack LX3 too. And it works smile.gif .
There are already two topics on CN:
https://www.cloudyni...x3-track-mount/
https://www.cloudyni...ta-100-300-apo/
I try to describe my procedure perhaps you see a difference?
1. Focus dslr on a bright star
2. Level Tripod
3. Mount your camera on the ballhead (When I was doing this after PA, my Rig was moving and PA was sometines gone)
4. Do polar alignment using the supplied polar finder.
5. Turn the clock
6. Do Framing ( You can try to do this before turning the clock, but by turning it your camera moves too)
Take pictures smile.gif ( I use internal delay Timer or a remote trigger)
Does the clock sounds the same without the camera as with mounted camera?
Be Careful with touching the mount after PA.
Hope this helps?
Kind Regards
Sven
Also tagged with one or more of these keywords: astrophotography, beginner, equipment
