Sizing DSO Objects?
13 replies to this topic
#1 Blackbelt76
Blackbelt76
Posted 22 January 2020 - 09:38 AM
This is the unprocessed image of M-81 stacked with DSS.
I shot this with a Nikon D300s w/ 200mm lens at f/4 unmoded.
20 lights x 75s iso 640
20 darks
20 bias
No flats
Question: Is 200mm simply not enough reach? Seems really small?
I understand the angular size is small, so perhaps I need to choose larger objects such as M31, M-42 etc.
My first attempt using the same setup of M-1 seemed better success, it too is small angular size?
https://www.cloudyni...st-m-1-attempt/
I can "scale" in Adobe PS, but only to a point.
Any advice appreciated.
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 22 January 2020 - 09:46 AM
I dont think thats M81 - I think you'd have it more clearly ,particularly having seen your M1 image. I think its a much fainter galaxy.
Also the star field looks wrong.
Can you plate solve the full image?
https://nova.astrometry.net/upload
#3 happylimpet
happylimpet
Posted 22 January 2020 - 09:55 AM
https://nova.astrome...37908#annotated
Yeah, you're waaaaaay off. Note i had to crop the full image to just the left side to eliminate the inset - but you get the idea!
http://www.worldwide...51307&wtml=true
On the other hand, lets accentuate th epositives and note the youve imaged NGC3877, a much fainter galaxy....
https://en.wikipedia.org/wiki/NGC_3877
Edited by happylimpet, 22 January 2020 - 09:57 AM.
#4 Blackbelt76
Blackbelt76
Posted 22 January 2020 - 09:57 AM
You may be right.
I don’t have software yet to plate solve. Just using the DSLR and skywatcher EQ6R unguided.
I was using the setting circles to star hop to it from MIzar.
Been checking my Redshift program trying to ID nearby stars close to the object.
Great link. I was unaware of it. Seems useful.
Edited by Blackbelt76, 22 January 2020 - 10:03 AM.
#5 Ishtim
Ishtim
  • Loc: N. Alabama, USA
Posted 22 January 2020 - 09:58 AM
Here's a handy tool to "size up" your equipment with various targets.  Choose the imaging tab and enter values for your equipment and desired target.
https://astronomy.to.../field_of_view/
  • Blackbelt76 likes this
#6 Blackbelt76
Blackbelt76
Posted 22 January 2020 - 10:42 AM
You may be right.
Seems to be NGC 3877?
Thanks for that link.
I've been away from astronomy for years; we did not have such a tool then.
#7 Blackbelt76
Blackbelt76
Posted 22 January 2020 - 10:55 AM
@Happylimpet.
Yep.
I sure did miss it.
Freezing my butt off this morning (20F), I think my setting circle slipped.
Was just using the Camera on the EQ6R.
OTOH..I guess I'm thrilled to have captured a 12 mag galaxy with a unmoded camera.
  • happylimpet likes this
#8 bobzeq25
bobzeq25
Posted 22 January 2020 - 11:04 AM
20 darks
20 bias
No flats
In addition to being off the target...
I don't think galaxies are a good target for 200mm.  Here's M31, which is gigantic.
https://www.astrobin.com/209498/
Nebulae and constellation images work better.  Orion (below) is spectacular, as is Deneb.
https://www.astrobin.com/227049/C/
#9 happylimpet
happylimpet
Posted 22 January 2020 - 11:48 AM
@Happylimpet.
Yep.
I sure did miss it.
Quite right to be thrilled! Dont let perfection be the enemy of good enough, or whatever the phrase is. Im sure you'll get a great (little) image of M81 when you get it framed!
I take huge pleasure in tiny little smudges in my image which are vast distances away or extreme objects in some way or other.
#10 JDShoots
JDShoots
  • Loc: Pennsylvania, North East
Posted 22 January 2020 - 12:18 PM
I am going to have to look into  affiliate links, because I seem to be recommending the same site a lot these days:)
I use Telescopius ALL the time to get an idea of size and framing.
I keep a list of targets I want to hit, and inside the page for each is a Telescope simulator.   In there you can enter your equipment and see what it frames up like.   As with daylight photography, I am always attempting to fill the frame with my subject, so it is nice to see what size a target is, and what field of view a particular lens has on my camera.
For my DX camera, my 135mm lens has a similar FOV as your 200 on the FX which is roughly 10° by 6.5°.  Then knowing Bodes is less then a 1/2° that doesn't fill much of the frame.  I plan on shooting Bodes soon, and will add a TC to my 500 for a 700mm lens, even that is a little short, thankfully there is more then one subject in the frame.
Here is a framing with a 700mm lens on a DX body.   Still small, but assuming the TC doesn't kill my image quality, it should be decent.
#11 Blackbelt76
Blackbelt76
Posted 22 January 2020 - 02:03 PM
@bobzeq25: Great M31 with a 200mm! Question: Did you scale the final image? It appears large from a 200mm w/o some scaling..
I generally do all my pre-post work in Capture NX at a pixel level,Then Adobe PS for bicubic enlargement with resample off. Last I do is "scale" where I seem to max out at about 250%.
@happylimpet: Appreciate the encouragement.
I've been away from this hobby a long time. I didn't have the tools I see today. Back then I used a 8" f/6 Newt (ground the mirror myself), cold cameras and gas hypered 35mm film; hand guiding for sometimes 2hrs while peering thru a 80mm APO (talk about tube flexure!)..ahh the good 'Ol days. smile.gif
When I re-entered this hobby, I was awe struck by the new technolgy available to the amateur. "Auto-Guiding" in particular when coupled to a computer is amazing; as are the new crop of CCD dedicated astro-cams. I can see how AP could get addictive, not to mention expensive from what I've seen. $$$
As I've only recently re-entered this hobby; I'm content trying to use my DSLR and simple visual only thru my newly acquired Celestron Edge 9.25".
I've considered mating the DSLR to the prime focus, but at f/10 I doubt it's a good choice for DSO. The focal reducers sure are not cheap nor is Fastar, which is pretty cool.
I will confess, as cold as it here at the moment in the midwest, with few consecutive clear nights in Jan or Feb, I am a bit lazy about polar aligning and I tend to rush my setup.
So far I must be getting lucky just doing the PA with the polar scope as my stars seem to exhibit little trailing if any up to 4 mins unguided. (No PEC)
I'm just outside a city of 200,000, LP is a big problem. The sky fog is quite noticeable and disappointing; especially to the east.
I'm finding focusing the DSLR quite a challenge, even using "Live-View" magnified. So far all I've done is focus the best I can and VERY gently place a piece of tape across the focus ring. My 80-200 f/2.8 is not image stabilized so I've ruled that out, but am starting to wonder as I slew to new positions if the lens may have some optical train components that may be shifting ever so slightly? Not a issue for normal terrestrial use, but AP is obviously a different set of rules.
Clear skies to all!
Edited by Blackbelt76, 22 January 2020 - 02:05 PM.
#12 bobzeq25
bobzeq25
Posted 22 January 2020 - 05:14 PM
No.  M31 is _gigantic_.  Over 3 degrees from end to end.  6+ full Moons.  If you could see it all with your eyes, it would look like something out of a science fiction movie.  <smile>
The next biggest is M33, about one degree.
Edited by bobzeq25, 22 January 2020 - 05:45 PM.
#13 Ranger Tim
Ranger Tim
  • Loc: SW Idaho, USA
Posted 22 January 2020 - 07:29 PM
M31 is a great object for a 200-300mm lens, especially for a beginner. It takes a lot more work to get it looking awesome though.
The dead of winter is a challenge for me. The seeing is usually terrible, there's a lot of clouds, and the temperatures are harder to tolerate than when I had more body fat. Can't wait for spring!!
#14 Blackbelt76
Blackbelt76
Posted 23 January 2020 - 07:13 AM
I know what you mean.
Here in the midwest, we get lousy weather in Jan..not much better in Feb.
I don't mind the cold; I can dress for it; the issue here is wind..30 degrees and a 10 MPH wind and I'm done.
