Installing Atik One 6.0 on a Rasa 8
5 replies to this topic
#1 ChristopherGem
ChristopherGem
  • Loc: Thüringen, Germany
Posted 24 January 2020 - 02:20 AM
Hello Folks,
I know this Proposition might be a bit crazy, but does anyone know if it is technically possible to install an Atik One on a Rasa 8? Obstruction would be Kind of significant, but I have seen some crazy large cameras used with this scope. One example would be here: https://www.baader-p...ghspeed-filter/ Spacing would be absolutely critical, since the backfocus of the Atik is 27.5 mm and the RASA requires 29 mm. Thoughts would be greatly appreciated!
Warm regards,
Chris
Edited by ChristopherGem, 24 January 2020 - 02:22 AM.
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 24 January 2020 - 03:03 AM
If you both then why not try it ?
Although you may need to add some blocking mask if you want avoid asymmetrical diffraction pattern.
#3 ChristopherGem
ChristopherGem
Posted 24 January 2020 - 03:23 AM
As of now I do not a RASA (since that is quite an Investment for me, I wanted to ask before making the dive :) ). The blocking mask is a good idea! Thanks! But I do wonder how that would potentially reduce the f-stop? Might be mistaken on that one. Regards,
Chris
#4 APshooter
APshooter
  • Loc: Camby, In.
Posted 24 January 2020 - 01:06 PM
I have both the Rasa and the Atik One. I might try it at some point, but currently its cloud city.
#5 ChristopherGem
ChristopherGem
Posted 24 January 2020 - 05:34 PM
That would indeed be formidable, if you could try that! Would you share your experience? Thanks!
#6 APshooter
APshooter
  • Loc: Camby, In.
Posted 25 January 2020 - 01:15 AM
If I can get it attached and in focus I certainly would post the results.
