yet another mirror refiguring question...
4 replies to this topic
#1 BDS316
BDS316
  • Loc: Sol 3
Posted 24 January 2020 - 11:55 AM
After a commercial mirror (Orion, GSO, etc) is refigured, will it still have the same focal length and f/ ratio so it can be put back in the scope without having to change the locations of the diagonal, focuser, etc and with all your eyepieces still coming to focus, as they did previously?
#2 Mike Lockwood
Mike Lockwood
    Vendor, Lockwood Custom Optics
  • Loc: Usually in my optical shop
Posted 24 January 2020 - 12:07 PM
In most cases, yes.
The exception would be if a large amount of polishing was required to remove bad astigmatism or a rolled edge.  In that case the focal length might change by 1/16" or a bit more, but this would be somewhat rare.
In the event that a re-grind is required, say in the case of a surface damaged by chemicals, the change could be larger depending on what tooling is available.  Hopefully this is even rarer.
  • Bonco2, happylimpet, Joe1950 and 1 other like this
#3 BDS316
BDS316
  • Loc: Sol 3
Posted 24 January 2020 - 12:28 PM
In most cases, yes.
Cloudynights is awesome...you ask a question and it gets answered by one of the world's leading authorities on the subject.  Thanks!
Next clear night I'll do a star test and report back.  I think I'm dealing with a tad of either under or overcorrection, I don't recall which one.
Which is the one where it's better inside of focus, ie eyepiece closer to OTA?
  • Joe1950 and Dougeo like this
#4 Mike Lockwood
Mike Lockwood
Posted 24 January 2020 - 12:48 PM
If you see rings (less blurry image) inside of focus but not outside, it is undercorrected.
If you see rings outside of focus but not inside, it is overcorrected.  However, this can be caused by cooling a properly corrected mirror, depending on substrate type.
http://www.loptics.c...rcorrection.jpg
  • BDS316, Bonco2 and Joe1950 like this
#5 BDS316
BDS316
  • Loc: Sol 3
Posted 24 January 2020 - 03:14 PM
Thanks.  so this picture would be overcorrected since the less blurry rings are outside of focus?
