SiTech question
2 replies to this topic
#1 Benach
Benach
Posted 24 January 2020 - 06:34 PM
Hi All,
Am currently configuring a SiTech II with a motor encoder on both axis and a shaft encoder on each axis. In RA every goes smooth and normal, but in Declination it is very weird. As soon as I press a button in the SiTech software, the motor will turn a fraction of a second, it is engaged to the worm gear and worm, but then goes "In Blinky" very shortly afterwards. Motors and all four encoders seem to be installed correctly. By resetting I can restart the system but a permanent solution has not been found yet.
It seems to me that there is something wrong in the configuration data. When I use the motor in RA, the number of motor encoder tics and shaft encoder tics both increase approximately at the same speed. In Declination this does not increase the same way although the gear ratios seem to be filled in correctly. See attachments to see what I mean.
Anybody got an idea? Cheers,
Benach
#2 freestar8n
freestar8n
    Vendor - MetaGuide
Posted 24 January 2020 - 08:30 PM
Hi-
I have things working well with Scitech motors but no scope encoders.
I would play with different combinations of the "Invert" settings for the Dec motor and encoder.  If the motor and scope encoders are opposite I think that would explain the problem.
Can you get it working with the scope encoder disabled first - and then add it?
Frank
  • DuncanM likes this
#3 Benach
Benach
Posted 25 January 2020 - 01:42 AM
Thanks for the idea. Will give that a try. This telescope and mount is at my astronomy club so progress is relatively slow. Next time I will be there is next Wednesday.
