Sky-Watcher refractor case and Moisture
4 replies to this topic
#1 tog
tog
  • Loc: Front Yard
Posted 25 January 2020 - 05:21 PM
The case that comes with the Sky-Watcher 100mm Evostar ED is pretty nice, but contains lots of cardboard. I sometimes have trouble remembering to close the lids on my gear once I begin to set up. You know how well cardboard and moisture like to get together in the dark! I thought about just removing all the cardboard from the case and replacing it with something else. But I didn't want to have to rip out all that foam so looked for another solution. I think I found something that might work-"plasti-dip". I laid down three coats of plasti-dip and let it dry for a day or two. The cardboard seemed to soak it up nicely until the 3rd coat was applied. I hit the edges of the cardboard heavy trying to seal them. Here is a pic of the results. Sky-Watcher, if you are reading this please use something else that does not attract moisture-Thanks!
Edited by tog, 25 January 2020 - 05:22 PM.
  • barbarosa likes this
#2 petert913
petert913
  • Loc: Portland, OR
Posted 25 January 2020 - 05:30 PM
Great idea !!  Sell it to SkyWatcher :)
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 25 January 2020 - 05:48 PM
As I recall my Skywatcher 72ED came with that stuff in the case. That was about 5 months back.
I know it is a foam and looks very much as the image - glossy black stuff, fairly firm, but it is foam.
Just looked: All internal sections are made from single foam sheets each about 3mm thick, glued I assume together. One is 5 sheets, another 6 sheets and the third is 8 sheets. These form the U shape into which the scope "drops". The 2 ends are rectangles of 8 or 10 sheets - sufficent to hold just compress the focuser end and objective ends inwards .
Seems a bit of an odd construction - lots of glued, either precut or glued and cut sheets.
Seems odd you got cardboard, never heard of it here.
#4 houndsbourgh
houndsbourgh
  • Loc: Hailey, Idaho
Posted 25 January 2020 - 06:07 PM
Cool idea! My SW Evostar 120ED came with the same case. The foam is divided by cardboard. I was thinking there had to be some solution without damaging the foam.
  • tog likes this
#5 JoeVanGeaux
JoeVanGeaux
  • Loc: SETX
Posted 25 January 2020 - 07:08 PM
I just happened upon this post.  If I'm seeing the photo correctly, that's a fairly straight piece of rectangular cardboard being used as a divider.
In both Home Depot, Lowes and most craft shops, there is a product called Coroplast - which is basically a corrugated plastic.  It seems to only come in white and translucent, as I recall.  The stuff would probably take Krylon Fusion paint pretty well, too, if you wanted to get arsty.  This is what a lot of campaign and realty roadside signs are made of.
Best of luck!
Joe
  • tog likes this
