Classic MIZAR Fans - Post Your Pix!
classic equipment
118 replies to this topic
#101 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 09 June 2021 - 06:15 PM
GT-80S was delivered late today:
Mizar GT-80S Delivery S03 - Focuser (Bottom).jpg Mizar GT-80S Delivery S04 - Focuser (Top).jpg
Took me hours to find a black rag loaded down with lint, but y'all are worth the effort.
Bare Tube weighs right at 5 lbs.  Tube Color is... unusual.  In bright LED light, it looks like Cream Of Wheat; but, in the man cave, it has a bit of Khaki.
The Focuser has about as many microscopic grub screws as my Tak FC-100 -- the assembly is a cap that threads off the tube, and has a micro-grub that must be loosened first.  For some insane reason, a prior owner used a clear sticky & tacky lube.  I'll scrub all that out this weekend, and replace with lithium grease.
I'm spoiled by two back-to-back Mint Mizars.  Both lenses will get DPAC'ed this weekend (Trust, but Verify!).  The cradle was in my Giveaway post.  Long term, I'll use it with the much shorter BN-80, but it fits this 80, too.
** Made the swap:  GT-80 is in the rings + 20cm SVBONY dovetail.  Clouds may be breaking...
Edited by Bomber Bob, 09 June 2021 - 07:47 PM.
  • steve t, Terra Nova, Kasmos and 1 other like this
#102 Bomber Bob
Bomber Bob
Posted 10 June 2021 - 11:03 AM
My 1st all-Mizar Astro Kit -- GT-80S + SP + MMD-III:
Mizar GT-80S 1st Setup S02 - FULL (RS).jpg Mizar GT-80S 1st Setup S04 - FULL (LS).jpg
Mizar GT-80S 1st Setup S03 - ZOOM (RS).jpg Mizar GT-80S 1st Setup S05 - ZOOM (LS).jpg
My only regret:  Not finding 1980s Mizar gear earlier.
For the Record
BN-80  FL = 400mm & F-Ratio = 5
GT-80S  FL = 560mm & F-Ratio = 7
I keep wanting to post 400 or 500mm for the GT-80...  Why?  IDK!!
Used to be, I had a bunch of scopes with 1200mm FLs; now, I have more around 600mm.  Lord!  With my rapidly declining...  whatcha call it? -- Short-Term Memory, there ain't no hope!
BIF:  Like the BN-80, the GT-80 needs a good lens cleaning.  Looks like the Seller wiped the front & back with damp lens (I hope!) tissues, and left streaks around the perimeters -- saw it when the lens fogged-up making the new Beauty Pictures...
Edited by Bomber Bob, 10 June 2021 - 11:34 AM.
  • CCD-Freak, steve t, mdowns and 4 others like this
#103 Bomber Bob
Bomber Bob
Posted 10 June 2021 - 11:49 AM
Y'all see what I mean about the GT-80's tube color?  Unlike the other Mizars that I've seen pix of...
Build Quality - Both 80s
Similar to Vixen.  Thick-walled tubes.  Precision castings & threads.  Nice!! & Resilient paints.  Lighter than Tak, but obviously inspired by Tak (I'm pretty sure both 80s have the same focuser tube male thread as my FC-50).  Baffles! & interior blackening, including rifling in the focuser tube...
Gonna verify, but I think most / all of the same-year Vixen rings & things will fit these 80s.  A good thing!  Mizar parts are hard to find -- that's an understatement.
So... Optics as good as Vixen?  DPAC will decide that.
FYI:  ALL of the knobs & slo-mo cables on both EQs are Mizar now.   It's the little things that add up...
AND... the 2 threaded holes on the focuser for the finder bracket have the same 28mm spacing as -- wait for it! -- Takahashi...
Edited by Bomber Bob, 10 June 2021 - 10:03 PM.
  • Terra Nova likes this
#104 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 10 June 2021 - 07:02 PM
Neat scope JW! Did you get the finder too?
#105 Bomber Bob
Bomber Bob
Posted 10 June 2021 - 07:05 PM
No finder on the GT-80.  Mizar finders are rarer than Mizars...  And, the bracket must have a flat base -- like Tak...
I need a credit line with Agena...  they have this flat (for Tak) Vixen-style Base:  https://agenaastro.c...se-silver.html
Edited by Bomber Bob, 10 June 2021 - 10:07 PM.
#106 Magnus Ahrling
Magnus Ahrling
  • Loc: Visby, Gotland, Sweden 57:30N.
Posted 11 June 2021 - 07:24 PM
Ah, at last I know what mount I had 1989-2008. A Mizar AR-1! Thanks everyone for the fine pictureswaytogo.gif Mine had aluminum legs and a polarfinder. I used it under an 8" Cave RFT f/4,5. It was ok up to 180X.
Magnus
  • Bomber Bob and Marcus Roman like this
#107 Bomber Bob
Bomber Bob
Posted 12 June 2021 - 11:05 AM
GT-80S - Lens Cleaning:
Mizar GT-80S Restore T01 - Lens (BF TOP).jpg Mizar GT-80S Restore T03 - Lens (Glue Spot).jpg Mizar GT-80S Restore T04 - Lens Cell (BF TOP).jpg Mizar GT-80S Restore T05 - Lens (AF TOP).jpg
It sure looked like one of the spacers was way out of place.  But once I had it apart, I found that it was intentionally glued closer to center than the other 2.  After cleaning & reassembly, I checked the Newton Rings, and they were spot on.  Green Light DPAC better than expected:  No Zones (the F5 BN-80 did show zones!), but slight turned-down edge -- overall, the pattern is similar to the AT102ED.
I know this lens was never messed-with -- glue spot on the outside of the cell.  Had to break it with my X-Acto, then clean both threads.  No alignment marks by the maker, so I added my own for the spacers & element placements.
Edited by Bomber Bob, 12 June 2021 - 11:06 AM.
#108 CCD-Freak
CCD-Freak
    Vendor - Portable Observatories
  • Loc: Whitesboro,Texas
Posted 13 June 2021 - 02:52 PM
I only have a Mizar mount at this point.
  • Bomber Bob, Kasmos and Marcus Roman like this
#109 CCD-Freak
CCD-Freak
Posted 13 June 2021 - 03:00 PM
The Mizar mount did a fine job imaging comet NEOWISE.
  • Bomber Bob likes this
#110 Bomber Bob
Bomber Bob
Posted 14 June 2021 - 09:24 PM
Fits like a glove on the GT-80's finder block on the focuser -->  Agena Synta/Vixen Style Dovetail Mounting Base/Shoe for Finders - Flat Base for Takahashi Scopes:  https://agenaastro.c...ase-silver.html
BIF:  Looks like the Baader 2" ClickLock with M42 Female port will fit the smaller rings on both 80s.
Edited by Bomber Bob, 14 June 2021 - 10:34 PM.
#111 Bomber Bob
Bomber Bob
Posted 16 June 2021 - 07:36 PM
ZEN must be using a Concorde SST -- this Classic Mizar FM-PH Kit arrived today:
Mizar FM-PH Delivery S02 - GT-80S (RS FL).jpg Mizar FM-PH Delivery S05 - GT-80S (LS FL).jpg
Mizar FM-PH Delivery S04 - GT-80S (RS CU).jpg Mizar FM-PH Delivery S06 - GT-80S (LS CU).jpg
Y'all, this thing looks like NOS (New Old Stock) -- no scratches or dings anywhere on the mount head, and just a few scuffs on the wood tripod.
Long term, the F5 Mizar BN-80 Nature Scope will be on display & in use with this mount, but I want to have time to adapt it's photo-tripod (1/4-20) plate to this mount's flat top.
Edited by Bomber Bob, 16 June 2021 - 07:38 PM.
  • CCD-Freak, mdowns, Terra Nova and 2 others like this
#112 Terra Nova
Terra Nova
Posted 16 June 2021 - 08:13 PM
The mount looks quite sturdy. The scope like a wonderful ST80 type RFT. You should have some fun this summer cruising the Milky Way with it.
PS- it looks longer than F5. Any idea why?
Edited by Terra Nova, 16 June 2021 - 08:14 PM.
#113 Bomber Bob
Bomber Bob
Posted 16 June 2021 - 09:36 PM
That's the F7 GT-80S on the mount.  After these pix, I swapped-in the F5 BN-80 Nature Scope -- bolted it via its tripod block to the SVBONY dovetail.  It works, but looks clunky.  I want a standard 1/4-20 assembly bolted to the head, and the BN-80 bolted to that assembly.  The shorter BN-80 looks right on the mount, and balances very well...
#114 Bomber Bob
Bomber Bob
Posted Yesterday, 07:56 AM
BN-80 on its AZ Mount + Tripod:
Mizar BN-80 AZ 1st Setup S02 - RS CU.jpg Mizar BN-80 AZ 1st Setup S03 - LS CU.jpg
What is it with Japanese F5 RFTs being equipped with / for small .965" format accessories??  The BN-80's eyepiece adapter, both prisms, & 3 (nice!) eyepieces are all small...
I'm gonna put a Baader 2" CL on this RFT -- really let her rip it open!
Edited by Bomber Bob, Yesterday, 10:05 AM.
  • CCD-Freak, mdowns, Terra Nova and 1 other like this
#115 Bomber Bob
Bomber Bob
Posted Yesterday, 04:35 PM
Forget Trickle-Down Economics!  At The Swamp, it's Trickle-Down Upgrades:  The mint condition 1980s gloss-black Celestron (V) 8x50 RA Polar Finder came in for my Tak FC-100, so that cheap GSO got yanked ASAP.  Note in the GT-80S pix above, the flat-base Tak-sized finder base is installed.  So, the GSO bracket is now on the GT-80; and, thanks to Michael, I have a 1980s blue Meade (MIZAR) 8x50 RA Finder headed my way:
Thanks Again, Michael!!  It should fit the GSO bracket; but if not, I have that fancy Vixen 2-ring bracket.  And a Bonus for Ole BB -- helical focuser!
#116 Bomber Bob
Bomber Bob
Posted Today, 10:27 AM
BN-80 -- Finishing Touches
Two Issues left to fix:
- Attaching the scope to the mount.  Looked at a bunch of different options, but most looked clunky.  So, I'm gonna replace the original tripod block with this SVBONY very short dovetail:
It will fit in one of the medium-size SVBONY dovetail clamps:
- Wood Tripod & Spreader.  The original wood tripod is the Towa style with a round dowel center leg, and traditional hinged spreader slats.  Looks brand new!!  But, the spread is too small for a standard Mizar "pie pan" tray; and, a Vixen SP triangle tray is too dang big!  The Atlas 60 F15 came with its original wood tripod + spreader chain.  It's in VG condition, and hefty enough for this ultra-light F5 frac + mount, so I'm gonna swap 'em.  I'll post pix once it's all purdee-ed up.  Once my Hy-Score 457 is gone, this kit will replace it as a Display.
#117 Terra Nova
Terra Nova
Posted Today, 10:35 AM
How about making a nice little wooden accessories tray that’s just the right size? It’s easy peasy and they look nice too.
  • mdowns, Bomber Bob, mikerepp and 1 other like this
#118 Bomber Bob
Bomber Bob
Posted Today, 04:10 PM
Thanks Again, Michael!   Got the "new" finder attached:
Meade (Mizar) Blue 8x50 RA Finder T12 (RS CU).jpg Meade (Mizar) Blue 8x50 RA Finder T13 (LS CU).jpg
Based on the hardware, I think this is a TOWA -- at least a couple of years before Meade switched to Mizar.  VG condition!
I'll leave the hardware black, and paint the tube a coordinating Khaki color.
Little Things:  The pair of chrome tube lock-levers came off an OLD small EQ.  I re-threaded them to standard 1/4-20.  A 4mm long vinyl rod + felt pad presses down on the scope tube -- no dinging (?), scratching, or marking the perfect original paint job.
  • mdowns likes this
#119 Bomber Bob
Bomber Bob
Posted Today, 04:12 PM
The Long & Short of it -- I really like my pair of Mizar 80mm fracs.  2 x 80s from the 1980s:
Mizar - 2 x 80mm Refractors T01 (RS FL).jpg Mizar - 2 x 80mm Refractors T02 (LS FL).jpg
(You haven't seen my wood-working!)  Got to looking at it, and I think I can remove the pins from the 3 slats, and replace each with a Triangle + Chain Length from the Atlas.  Quick-folding like my VG2 tripod, and another easy to reverse mod by the next owner...
Edited by Bomber Bob, Today, 04:16 PM.
  • mdowns and Terra Nova like this
Also tagged with one or more of these keywords: classic, equipment
