Dovetail mounts?
accessories beginner equipment mount refractor astrophotography
11 replies to this topic
#1 astronomykiwi
astronomykiwi
Posted 26 January 2020 - 07:11 PM
With the skywatcher esprit 100ed super APO triplet, I noticed it has a "D style dovetail" I'm not sure as to what this is and wether I need some sort of adapter to attach it to my HEQ5 pro, I have considered upgrading to the EQ6 R PRO so that the mount is comfortably in the weight capacity but then noticed that has a "dual saddle" mount. Could someone please explain these?
#2 Astrola72
Astrola72
  • Loc: Maryland, USA
Posted 26 January 2020 - 07:29 PM
"V"=Vixen (narrow), "D"=Losmandy (wide). Dual saddle handles either V or D. But you can always replace the dovetail on the esprit 100 with a Vixen dovetail.
#3 astronomykiwi
astronomykiwi
Posted 26 January 2020 - 08:23 PM
In the image of the esprit it almost appears to be a losmandy with a vixen on the bottom of it? But it looks like the vixen is wider than normal and the losmandy is narrower than normal
#4 astronomykiwi
astronomykiwi
Posted 26 January 2020 - 08:24 PM
https://www.jacobsdi...ant=21154371460
#5 Astrola72
Astrola72
Posted 26 January 2020 - 10:19 PM
The ad states "Celestron CGE style dovetail". That's the larger "D" type.
#6 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 26 January 2020 - 11:10 PM
Your HEQ5-pro won't handle the CGE-"D" dovetail that comes on the Esprit 100.
A Vixen-style dovetail isn't that expensive, but you will need to get one for the scope to put it on that mount.
Here's a pic (from CN) that shows the difference...
#7 astronomykiwi
astronomykiwi
Posted 27 January 2020 - 05:40 AM
In the spec chart it only says D type dovetail. Thanks for clearing that up!
Edit: oops hadn't seen it or atleast recognised what it was meaning
Edited by astronomykiwi, 27 January 2020 - 05:42 AM.
#8 astronomykiwi
astronomykiwi
Posted 27 January 2020 - 05:44 AM
Yeah that's more the difference I was expecting. The Heq5 did come with a dovetail bar, but would it be safe to put such a heavy scope on that style or should I get a eq6r Pro as soon as possible after getting the scope
#9 OldManSky
OldManSky
Posted 27 January 2020 - 08:52 AM
My recently-purchased Zenithstar 103 came with a Vixen-style dovetail bar.  It mounted on my CEM60 fine, but I thought it was a bit...um...under-mounted.  So I bought a larger D-style plate, and mounted it on that.  Fortunately the CEM60 can take both kinds of dovetail bars, while your HEQ-5 can't.
I would say give it a try with the Vixen plate first.  If everything works OK, then don't worry.  There's no doubt the EQ6-R Pro is a significant upgrade from the HEQ-5, but before you lay out the cash I'd try things out first :)
#10 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 27 January 2020 - 08:54 AM
You can get a dual saddle for your HEQ5 from ADM that will accept both dovetail sizes.
  • SilverLitz and OldManSky like this
#11 astronomykiwi
astronomykiwi
Posted 28 January 2020 - 03:23 AM
Yes exactly, I was only planning to upgrade the mount if I had issues with the Heq5 which I probably will, but the heq5 will hopefully handle until I get the money.
#12 astronomykiwi
astronomykiwi
Posted 28 January 2020 - 03:26 AM
Looking at it I don't think I'd trust that round dovetail thing with 8kg+ of weight, it would probably be fine but it's be just as easy and cheaper just to screw a dovetail to the existing one
Also tagged with one or more of these keywords: accessories, beginner, equipment, mount, refractor, astrophotography
