FSQ-85 visual clamshell holder...
2 replies to this topic
#1 trist007
trist007
Posted 26 January 2020 - 09:17 PM
If using the scope for visual with something as heavy as a 2 inch diagonal with a 41mm panoptic eyepiece do you need the clamshell that holds the ota farther forward or will the regular 95mm clamshell do just fine?
-Tristan
Edited by trist007, 26 January 2020 - 09:31 PM.
#2 213Cobra
213Cobra
  • Loc: Los Angeles, California, USA
Posted 27 January 2020 - 04:32 AM
If you use the offset, then balance won't be ideal with some light eyepieces. If you don't use the offset, some heavy combinations of cannonball eyepieces with massive diagonals won't be idea either. I have both clamshells for different mounts. I can make any eyepiece/diagonal combination work with either clamshell. I have to, because I don't have any visual sessions wherein I am using exclusively massive eyepieces all night.
Phil
#3 trist007
trist007
Posted 27 January 2020 - 10:22 AM
Great answer thank you!
