TS (Sharpstar) 140mm triplet F6.5
44 replies to this topic
#26 LRSibb
LRSibb
Posted 09 March 2020 - 01:19 PM
Received the 2.5 Inch Flattener from Sharpstar directly - no sign of 3 inch reducer yet.
Picture of 2.5 Flattener on scope:
  • zjc26138, eros312 and denis0007dl like this
#27 LRSibb
LRSibb
Posted 09 March 2020 - 01:40 PM
Looking at the Sharpstar site -  it appears that the backfocus requirement varies by FL - for the 910 mm 140PH  I will need to bring it up to 88mm. Pictured above is standard 55mm which will have to be lengthened.
Edited by LRSibb, 09 March 2020 - 01:41 PM.
#28 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 10 March 2020 - 06:36 AM
There is a nice camera rotator collar that moves smoothly.
Where is this rotator situated?  Is it at the 'big end' (telescope side), or the last (smallest) element?
I.e., if I add a reducer etc. to the 68mm thread, can I adjust the whole unit that way?
I found the TSFlat25Del that would connect directly to the M68x1 and have M48 with 55mm BF on the other side, which would directly connect to the ZWO package (OAG, EFW and camera).  It's only a 2-lens flattener though - not sure about the optical/color quality...
Edit:  So is it the yellow/brass screw that secures the rotation?
Edited by Der_Pit, 10 March 2020 - 06:37 AM.
#29 LRSibb
LRSibb
Posted 10 March 2020 - 12:21 PM
The rotator is at the "big end"  - yes the brass colored knob is the securing screw for it.
Yes - The entire unit then moves with the rotator.
A correction - the picture above with the Sharpstar Flattener is correct within a mm or two  - The 88-90 mm backfocus includes the conical adapter.
#30 elgol20
elgol20
Posted 12 March 2020 - 04:00 AM
can you comment on the spotdiagrams?
I wonder why the Sharpstar seems to have quite large ones.  I tried to insert the ones from RASA 11 and Tak FSQ 106, scaled,
taken from
 http://www.sharpstar...series/232.html,
 https://www.astronom...ount-12078.html
http://www.takahashi...ptics.spots.htm
  • MirkoV69 likes this
#31 sharpstar
sharpstar
    Vendor
Posted 15 March 2020 - 04:01 AM
It's not correct way to compare , because:
1) You used a center spot of FSQ but not use a edge (22mm) spot to compare. You can see at the edge of full frame, our spot is smaller.
2)Our center spot is a bit big because we consider entire image which should be average, we of course can let center spot smaller, but the edge spot  will be bigger.
3)The wavelength are not the same, our wavelength is from 436 to 707,other brands some APOs normally is from 436 to 656.
Thank you.
Edited by sharpstar, 15 March 2020 - 08:56 AM.
  • eros312, Tyson M and 25585 like this
#32 MirkoV69
MirkoV69
Posted 16 March 2020 - 11:11 AM
Hello
They now corrected the description on TS web page for the corrector, specs are now matching the Sharpstar reducer for 140
(still the Technical Data tab in English is mismatched but the German one is consistent)
Mirko
  • 25585 likes this
#33 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 18 March 2020 - 04:39 PM
Yes, they eventually have received the first batch, and substantially updated the webpage.
So I finally pulled the trigger and ordered one, together with an Riccardi 1x flattener.  I just hope it can make its way to the Canaries in all this Corona-chaos shocked.gif
  • 25585 and MirkoV69 like this
#34 25585
25585
Posted 19 March 2020 - 06:07 PM
Canaries are in lock down like the mainland Spain?
Edited by 25585, 19 March 2020 - 06:08 PM.
#35 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 20 March 2020 - 05:37 PM
Yes, traveling and individual mobility are regulated here, too.  But freight should work, at slower-than-usual pace though (and the usual one is already quite - unhurried).  I'll see what happens.
  • eros312 and 25585 like this
#36 25585
25585
Posted 20 March 2020 - 05:41 PM
My brother is in Tenerife. Only 1 person per car now he says.
#37 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 20 March 2020 - 05:54 PM
Yes, and they have police control points at many places, asking everyone in a car why/where he/she's going.   But so far it seems to go quite smooth here.  Really tough though for all the small shops etc.  My friends have a dive center, and now sit at home and watch as money drains :(
Sorry for slightly OT.
As for topic:  I'll of course report once I have it :D
  • 25585 likes this
#38 MirkoV69
MirkoV69
Posted 22 March 2020 - 12:40 PM
Hello all
Did you see the unboxing of the 140 on TS instagram ?
https://www.instagra...g_web_copy_link
awesome !
Stay safe guys
Mirko
  • 25585 likes this
#39 LRSibb
LRSibb
Posted 22 March 2020 - 03:01 PM
Received and installed the 3" Reducer /Flattener.
Focus now almost at shortest position - nail biting when I focused it..... First light subs look great.
  • 25585, Der_Pit and MirkoV69 like this
#40 LRSibb
LRSibb
Posted 22 March 2020 - 06:21 PM
First Light Sharpstar 140PH w/reducer
IC 443 in bicolor
Only 2 Hours of data - 3x 1200 sec Ha , 3x 1200 sec SII
ZWO 1600 MM Pro CGEMII (DIYHypertune) , ZWO OAG, 174 MMmini Guide Camera
March 20 2020 Backyard Calgary Alberta - Significant LP (too much for OIII)
https://www.astrobin...a4ha36/?nc=iotd
  • zjc26138, eros312, Der_Pit and 1 other like this
#41 MirkoV69
MirkoV69
Posted 23 March 2020 - 04:20 AM
Sweet !
thanks for sharing
Mirko
IC 443 in bicolor
  • LRSibb likes this
#42 LRSibb
LRSibb
Posted 30 March 2020 - 10:21 AM
More first light work with the new 140 - Comet C/2019 Y4
https://www.cloudyni...tack-and-video/
  • zjc26138, eros312, 25585 and 1 other like this
#43 MirkoV69
MirkoV69
Posted 01 April 2020 - 03:18 PM
WOW , really nice !
The more I see, the more I get convinced this will be my next telescope.
May I as what mount you are using ?
thanks
Mirko
#44 MirkoV69
MirkoV69
Posted 01 April 2020 - 03:20 PM
WOW , this is very nice!
The more I see , the more I am convinced this will be my next purchase.
May I ask what mount are you using?
thanks
Mirko
#45 LRSibb
LRSibb
Posted 01 April 2020 - 03:41 PM
thanks
Mirko
I am using a DIY Hypertuned CGEM II.  The scope and instrument load is about 28 pounds.  With the OAG I am getting good enough guiding to image at full focal length especially with good seeing.
Stars are sharp to edge of APS C size 071 chip - using the 2.5 inch flattener.
