Earlier this week I received a TV76 to complete my collection of refractors up through a 130mm. For me, anything larger (then 130mm) and it won't get used very often. Anything smaller (then 76mm) and the views are unfulfilling. This is a subjective limitation only valid for me - yours may be different. But really if your using something less then 76mm of aperture, why spend the time setting up a tripod and mount? Just use binoculars instead!
I currently own complete sets of Nagler T4, T5, T6, Delos and Delites a set of TV Plossls and a sprinking of Panoptics. The only non-TV eyepieces that I own is a full set of Japanese Fujiyama Orthos. But, I had not owned a TeleVue OTA in at least 12 years. And, now, all TeleVue OTA's come standard with the 2-speed focuser - except the TV60 and the specialized FLI imaging OTA. At TeleVue, fine focusing has evolved over the years from a home-brew design to now using the StarLight Instruments pinion mechanism. TeleVue has done a good job incorporating the StarLight hardware into the look/feel/ruggedness of the OTA.
The Televue 76 is a stout observing package with the best build quality in its aperture class. Optically, I have found TeleVue OTA's to be - overall - very good, but not great with one single exception - my first NP101 which was phenomenal.
To me, the best thing about owning TeleVue is that you've bought into a system where all the accessories are designed to seamlessly (more/less) work with each other. You never have to venture outside of the TeleVue ecosystem if you don't want to.
In any event, here is the TV76 on the bench in double pass autocollimation. I did perform indoor star tests, too, but still need to stack and process the .avi into single frames. But, to be clear, the star test will not tell you much more then the DPAC images do.
Comments and criticisms welcome.
Edited by peleuba, 04 February 2020 - 02:01 PM.
