Where to find optical spectral datacubes?
2 replies to this topic
#1 jeffsuth
jeffsuth
Posted 07 February 2020 - 03:49 AM
I'm building a Littrow spectrograph, and playing around with the design parameters in Matlab via raytracing. I would like to find an optical spectral datacube to simulate realistic entrance rays. Does anyone know where I might find one?
I found a few sources for radio emissions, but nothing for visual wavelengths. I would ideally like the full 600-700nm range in high resolution (R=15000), and 350-900 in R=~2000-3000. In reality, I'd be happy with anything.
Any suggestions? Bonus points for M27 or something that I can eventually image and compare results against the reference.
#2 Todd N
Todd N
Posted 07 February 2020 - 01:34 PM
Outside my knowlege but I found this online:
https://www.bodkinde...ectral-imaging/
https://www.bodkinde...aging-products/
  • jeffsuth likes this
#3 jeffsuth
jeffsuth
Posted 07 February 2020 - 04:43 PM
Thanks for the links Todd, I sure like the idea of the hyperspectral camera...
With my low resolution datacube ask I'd like to test the feasibility of a CTIS (computed tomography imaging spectrometer). The main idea is that you spread the spectrum across 2 axes, including the -1,0,1 orders on both axes, and then each pixel becomes a sum of calculable frequencies, which you solve for. I feel like it should be extremely simple and cheap to make given it's basically a field stopped re-imager with a 2d diffraction grating in the collimated section.
I made a very simple Excel sheet to model the parameters to find spectral and spatial resolution and field size. I played around with some quick numbers to see what you could get on my imaging sensors with the cheap plastic gratings you can get on ebay, and it looks like I could get a R=500-1000 or so for each pixel of a 5'x5' fov.
CTIS design spreadsheet
Sounds pretty neat anyway. Because you get 9 images in the shot you could probably dither the data for higher spectral and spatial resolution.
For simulating in the raytracer, I was just going to add an image based ray source and pretend it's like an infinitely far patch of sky... then fire in the whole datacube a bunch of times and see what happens, lol! :D
