Flat Fields for a 5" F5 RFT
classic equipment eyepieces refractor
14 replies to this topic
#1 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 13 February 2020 - 06:58 PM
Ol' BB is looking for 2" eyepiece recommendations for a vintage (non-ED) 5" F5 triplet RFT.  I'll take flatter over wider, but a good compromise between those two traits will work.  Naglers have done very well in this old frac, but I haven't seen any in the 30mm to 20mm range.  Any tried & true favorites out there?
  • NC Startrekker likes this
#2 NC Startrekker
NC Startrekker
  • Loc: Sandhills of NC
Posted 13 February 2020 - 07:17 PM
BB... How about the Nagler 22T4 or the Nagler 31T5?
  • Bomber Bob and havasman like this
#3 stevew
stevew
    Now I've done it
  • Loc: British Columbia Canada
Posted 13 February 2020 - 08:50 PM
Bob, tell us what eyepiece you have tried in your RFT.
#4 Bomber Bob
Bomber Bob
Posted 13 February 2020 - 09:23 PM
In 2" format:  Erfles, Kellners, & Plossls -- all vintage.  In 1.25" format:  A-T Paradigms, Erfles, Kellners, Naglers, Plossls, RKEs, & Radians.
So far, the Nagler gives the largest + flattest field.  The Paradigm does well -- especially for the price -- edges out Plossls.
Naturally, I'm looking at used (but not abused), as I won't spend more on an eyepiece than the scope is worth.  But, it's a fun frac that pulls in a lot of stars, even in my backyard, so it's worth some upgrades.
Edited by Bomber Bob, 13 February 2020 - 09:27 PM.
#5 junomike
junomike
  • Loc: Ontario
Posted 13 February 2020 - 09:46 PM
31T5 would be my choice but the 35 Pan might be better for some.
#6 Jon Isaacs
Posted 13 February 2020 - 09:49 PM
The scope itself has noticeable field curvature so that's part of the equation.
Generally though at F/5, the eyepiece's astigmatism overwhelms the curvature unless it's a very well corrected eyepiece. Such eyepieces are not inexpensive to say the least.
In my experience, the 31mm Nagler and the 35 mm Panoptic are at the top of the list. From there, a step down, are the Explore Scientific 82° and 68° eyepieces.  Still very good eyepieces.
Probably not much help... still expensive.
  • Sarkikos likes this
#7 SeattleScott
SeattleScott
Posted 13 February 2020 - 09:56 PM
ES 24/82? I use mine at F4 in coma corrected newt.
#8 39.1N84.5W
39.1N84.5W
    He asked for it
  • Loc: cincinnati
Posted 22 February 2020 - 08:41 AM
Life is short. Buy a used 31mm Nagler and be done with it. You can easily sell it later... if you take care of your gear. Clear skies.
  • Jeff B, Sarkikos and NC Startrekker like this
#9 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 22 February 2020 - 12:42 PM
Your triplet might have decent color correction.  But an eyepiece won't flatten the field curvature of the telescope.  If you want a flat field for your well-corrected wide-field eyepieces in your triplet, you need a field flattener.
TS-Optics REFRACTOR 1.0x Flattener and Field Corrector - 2" connection
https://www.teleskop...connection.html
The TSFLAT2 has worked well in several of my achromats and ED/APOs.
Edited by Sarkikos, 22 February 2020 - 01:04 PM.
  • jeffmac likes this
#10 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 22 February 2020 - 12:47 PM
Erfles are generally poor performers in fast scopes as they exacerbate field curvature. Have you tried the BST Flat Field eyepieces? The 19mm has a 65° AFOV and does very well in my Custom-made 80mm F5 RFT.
#11 Sarkikos
Sarkikos
Posted 22 February 2020 - 12:51 PM
You don't buy an eyepiece for just one scope.  You buy it for all your scopes.
Likewise for the TSFLAT2.  It will probably work well in several of your refractors.
Edited by Sarkikos, 22 February 2020 - 01:01 PM.
  • Jon Isaacs and mrsjeff like this
#12 junomike
junomike
  • Loc: Ontario
Posted 22 February 2020 - 01:52 PM
Interesting option.  Do you affix it to the telescope side of the Focuser?
#13 Sarkikos
Sarkikos
Posted 22 February 2020 - 03:24 PM
The TSFLAT2 screws onto the telescope end of the diagonal.  You attach it to the diagonal, and then the TSFLAT2 slides into the visual back of the refractor.  Here's a thread with more information:
Field Flatteners for Achromats, Visual Only
https://www.cloudyni...ts-visual-only/
Depending on the focal length of the telescope, you either screw the TSFLAT2 to the 48mm threads on the barrel of the diagonal, or you take off the barrel and screw it directly to the back of the diagonal.  If the diagonal has SCT threads, you need an 48mm/SCT adapter ring between the TSFLAT2 and the diagonal threads.
Edited by Sarkikos, 22 February 2020 - 03:28 PM.
#14 junomike
junomike
  • Loc: Ontario
Posted 22 February 2020 - 04:10 PM
Thanks for the info.  From the initial ad I thought it went on the Lens side of the Focuser (which might be difficult to do).
#15 areyoukiddingme
areyoukiddingme
Posted 22 February 2020 - 04:22 PM
FWIW, I've found the flattener works, but it's not completely consistent with eyepieces.
For example, in my Stowaway, the 12.5 Docter adds astigmatism at the edge when the flattener is installed.
I haven't been systematic about comparing all my eyepieces, but this one stands out.
  • Jon Isaacs and Sarkikos like this
Also tagged with one or more of these keywords: classic, equipment, eyepieces, refractor
