Buying StarSense but need to know please.
13 replies to this topic
#1 MickTaurus
MickTaurus
  • Loc: United Kingdom
Posted 14 February 2020 - 12:49 PM
Hi, as title says! (this will be for my NexStar 8se).
What do I do with the original hand control, as I will be using the star sense HC.
Do I remove it or just leave it in situ?
Also should I try it out when I get it, or do a firmware update straight away?
  • carver2011 likes this
#2 5dave
5dave
  • Loc: Arizona
Posted 14 February 2020 - 12:53 PM
I would remove the old handset and store it for use if the StarSence fails. I would also check what version the firmware is and update if needed.
  • dswtan and MickTaurus like this
#3 pkrallis
pkrallis
  • Loc: Colorado Springs, CO
Posted 14 February 2020 - 01:18 PM
Good advice from 5Dave but my original HC has sat idle for 3 years now.  They are long lived little critters.
#4 MickTaurus
MickTaurus
Posted 14 February 2020 - 01:28 PM
#5 Noah4x4
Noah4x4
  • Loc: Colchester UK
Posted 14 February 2020 - 01:49 PM
Keep the Nexstar + HC as it might be useful, and not merely as a back up if the Starsense HC ever fails. It has some diagnostic and other functions not inherent in the Starsense version. For example...
A couple of years ago, we were suffering from the 'Starsense on wedge bug' (now fixed). For some months, Celestron wouldn't acknowledge its existence. Then, I tried something a tad bizarre. I plugged in both controllers; aligned with Starsense using the ASPA routine; then compared the axis and PAE data read outs from each HC <via Menu>. This data differed, ultimately proving the existence of the 'bug'. Celestron then completely recreated the Starsense ASPA routine from the bottom up and it now works fine. There are also  a number of menu functions in the Nexstar + that don't feature in the Starsense version.
I am NOT advocating anybody routinely plugs in both simultaneously, notably as if you attempted a GoTo on the second device your scope would 'lock up. Simply that on RARE occasions it might assist. For example, whilst Celestron were fixing the said 'bug' I had the fall back of the Nexstar + ASPA routine, and the Starsense HC temporarily returned to its box.  I might never plug it in again, but it is reassuring to have both.
EDIT - didn't answer OP's other question.
It is vital that your Starsense HC firmware is dated 2019 or later. New devices sometimes sit on wholesaler and retailer shelves for long periods before despatch. Mine had firmware three years out of date. Prior to 2019, there were some major bug fixes. Later updates tend to me more cosmetic. But you can check on the Firmware Revision History on the Celestron website.
Edited by Noah4x4, 14 February 2020 - 01:54 PM.
#6 MickTaurus
MickTaurus
Posted 14 February 2020 - 02:41 PM
Thanks for that Noah, and 5dave.
I will check firmware when I receive the StarSence and report back if I have issues.
#7 carver2011
carver2011
Posted 14 February 2020 - 08:47 PM
Once you get past the learning curve you’ll be glad you bought the Starsense. For me it’s the best thing since sliced bread. I have a Evolution 8, and in all reality didn’t need Starsense. Doing 2 star alignments was easy. But I couldn’t resist the technology. Starsense is amazing. All I have to do is turn it on and a few minutes later I’m observing. It’s a crowd pleaser at outreach events when people see it slewing around. As Noah4x4 says , check the firmware version you have, and if it’s old, do and update. I bought my Starsense late 2018, and it’s firmware was 2016.
You might want to enjoy your new scope awhile before learning the Starsense, and use the NexStar hand control. I use mine when I just want to run outside for a quick planet view. I do a one solar system alignment.
Enjoy your new scope, it will give you many hours of enjoyment
Ed
#8 Noah4x4
Noah4x4
Posted 15 February 2020 - 01:58 AM
Good advice from Ed; learn to use Nexstar + HC before adopting Starsense, although I think this step has already occured with the OP.  I mention because I didn't.
Then, when I upgraded from a Starsense Auto-Align (that I used for visual) to a Starsense ASPA Polar Align (for AP) that was then suffering from the infamous Starsense on wedge bug (now fixed), I found myself dependent on a EQNorth + ASPA + EQNorth process using the Nexstar + HC. But because I had never mastered a regular Nexstar + Two Star Align,  the learning curve appeared much steeper. I had to revert right back to basics having been spoilt with the ease of Starsense.
This challenge of changing devices can be particularly acute for owners of the Evolution that have never used any HC having kicked off with Tablet/WiFi. In the UK, there was a period where some Evolution bundles were not even supplied with a Nexstar + HC. Whilst a Two Star Align is easy (with hindsight), going back having bypassed it and having benefitting from tablet control somehow appears more challenging.
More generally, as you add devices, I think it's good practice to comprehensively learn each individually. Many folk try to embrace Scope, Starsense, GPS, AP etc at first light then can't identify why something is failing. Reading each instruction manual and adopting devices sequentially rather than simultaneously has much merit.
Edited by Noah4x4, 15 February 2020 - 02:01 AM.
#9 MickTaurus
MickTaurus
Posted 15 February 2020 - 03:55 AM
I started with a NexStar 90 Mak, and then upgraded to 8se six months ago so yes I am familiar with the scope and HC.
I'm only doing visual, just did not know what to do with the 8se HC when I get the StarSence next week.
One for each hand maybe! wink.gif (no I'll store it).
Thanks Ed, and thanks again Noah.
#10 MickTaurus
MickTaurus
Posted 15 February 2020 - 01:15 PM
Just realised I think.
Am I right in thinking that I have to remove original HC, and replace it with the starsense HC?
#11 Noah4x4
Noah4x4
Posted 15 February 2020 - 01:32 PM
Absolutely correct.
#12 MickTaurus
MickTaurus
Posted 15 February 2020 - 01:44 PM
#13 orionic
orionic
  • Loc: Boulder, CO
Posted Yesterday, 06:16 AM
I tried updating my StarSense firmware a couple times in 2017, always got errors, and gave up.  The thing basically works, although I did get occasional "alignment error too large" errors.
I suppose the following thread is the place to check for challenges & solutions in the update process:
https://www.cloudyni...updates/page-10
The occurrence of "bricked" mounts in that thread is very disturbing.  Is there a "risk free" way to do the update that we should know about?
Edited by orionic, Yesterday, 06:17 AM.
#14 Noah4x4
Noah4x4
Posted Yesterday, 08:29 AM
The problem back in 2017 was an abundance of problems with not only Starsense, but with CFM. Also people were trying to download updates using the (then) flaky Celestron WiFi and using non-Windows computers. Things have much improved and you can safely update today using these original 'pinned' instructions I posted in December 2016.
The Starsense (and CFM) Firmware after 2017 has been almost completely rebuilt since then, including a significant number of bug fixes. "Bricked mounts and HCs " won't occur if you carefully follow these instructions. But if you don't or try ambitious stuff then you may inevitably have a spot of bother.
1. First download the latest version of CFM on a Windows PC.
2. Next get the latest version of JAVA
3. Follow the original instructions that I posted in the pinned thread mentioned using an appropriate cable.
There are posts #2 and #3 in that thread from Cray2Mpx and Roelb that add more information. But I got Moderator Brian Risley to clean up my post to offer better clarity before it got 'pinned'.
4. WiFi might still be problematic if using older adapters - my advise is ONLY use cable from HC to Computer.
Your Starsense update will then be fine. I have been using this procedure for four years with zero problems. But if people want to depart from this and use WiFi or Apple Macs (or whatever), then they need to read the entire thread for variants. However, various updates followed to permit such variants. But the original guidance using an appropriate cable continues to have integrity.
  • MickTaurus likes this
