Modifying Canon SL1
4 replies to this topic
#1 crunchygranola
crunchygranola
Posted 14 February 2020 - 08:16 PM
I've been on the fence a while about modifying my Canon SL1 for Ha.
Has anyone ever done it to to this particular camera? Any tips or links to look at for doing this?
I found a pretty decent tutorial to do it: https://www.lifepixe...ersion-tutorial
But is it completely necessary to install some kind of replacement filter?
Edit: Some more info. I'm shooting from a bortle 6 area with primarily LED street lights. I would be pairing the DSLR with an IDAS D2 light pollution filter, and I'm also thinking of getting some more granular narrow band filters.
Edited by crunchygranola, 14 February 2020 - 09:00 PM.
#2 StarBurger
StarBurger
  • Loc: North Country NY
Posted 14 February 2020 - 09:42 PM
Not quite the same but I modified an old Canon XS and removed all the filters ahead of the sensor( full spectrum mod).
Once you do this mod then the choice is yours whether you install a clip in filter in the camera itself or place whatever filter you need in the optical train ahead of  the camera sensor.
My choice was to put a 2" Baader  Moon and sky glow filter  in front of the camera to knock down the UV (reducing blue star bloat  and sodium light pollution) and still transmitting the H a. to it's max.
The full spectrum mod leaves room for any filter you wish to place in front .
Then you can experiment with IR/UV /CLS or whatever filter knowing the camera is in its native raw, naked  state.
#3 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 15 February 2020 - 12:28 AM
Mod info here...; should be relevant. Mod types here.... Regards
#4 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 15 February 2020 - 12:56 AM
If you do not install some type of glass filter ahead of the sensor, the image will focus in a different plane and camera lenses may not reach infinity; autofocus certainly won't work.  For use with a telescope, that might not be a problem.
#5 crunchygranola
crunchygranola
Posted 16 February 2020 - 07:39 PM
Removed just the LPF-2 tonight following the lifepixel tutorial.  Broke a little bit of plastic on the inside, stripped a couple screws but all in all the camera seems working fine once reassembled.  I'm going to take a few quick untracked shots tonight and see how it goes.
