We need T-mounts for mirrorless cameras that are short
5 replies to this topic
#1 RichA
RichA
  • Loc: Toronto, Canada
Posted 14 February 2020 - 09:47 PM
Most of the T-mount adapters for mirrorless cameras are deep, designed to make the mirrorless camera mount-sensor separation the same as old DSLRs, much longer.
I think the new full-frame Nikon mirrorless Z-cameras have a mount flange to sensor depth of 18mm or so.  This compares with 49mm for the average sensor to mount distance.  What I've found is that in-travel in focusers doesn't leave much room with these long T-mounts used with mirrorless cameras.  What I would like (even though in some instances I'd have to use an extension tube, depending on the scope) would be a low-profile T-mount system like you have with the DSLRs.  Here is a comparison of the T-mount for a m4/3rds mirrorless camera and a Nikon DSLR system:
#2 rk2k2
rk2k2
  • Loc: Cool, CA
Posted 14 February 2020 - 11:01 PM
I'm not positive if it was for my m4/3 or my Nikon, but I bought a 'low profile' adapter- I can't seem to find it right now but I'm almost positive it was for the m4/3- the Nikons are already low profile.  In fact, now that I remember, it was so I could slide my PL7 directly into a Baader click lock on my VC200l and be able to adjust the right distance (63.5mm?) from the focal reducer.  I think I googled something like 'micro 4/3 low profile adapter'.  It was like $40 vs the regular cheap ones you can get off Amazon for $10. ... in case that is what you're talking about.  I'm on short break from imaging but I'll look around later in case no one answers on identifying the part
Yeah, I found the box but the actual adapter is nowhere to be found.  In case what you are looking for is what I'm thinking, mine is called a Wide and Short T-minus Ring (for micro 4/3).  You can get them in either 42mm or 48mm thread.  The 48mm:
https://www.amazon.c...ASIN=B07NCNWL3Y
They are available cheaper (about $25) elsewhere
Edited by rk2k2, 14 February 2020 - 11:28 PM.
#3 B 26354
B 26354
  • Loc: Southern California semi-desert (NELM mag 5.3)
Posted 14 February 2020 - 11:25 PM
Maybe this is it?...
https://www.telescop...ss-cameras.html
#4 Traveler
Traveler
  • Loc: The Netherlands
Posted 15 February 2020 - 12:27 AM
Or maybe this one from Baader:
https://www.baader-p...ultrashort.html
Optical length = 2mm
#5 B 26354
B 26354
Posted 15 February 2020 - 11:09 AM
Or maybe this one, which is supposedly made specifically for Canon mirrorless cameras... as the other one that I posted is for mirrorless Nikons:
#6 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 15 February 2020 - 07:52 PM
My attempt at low profile adapter.... Regards
