How tight can you tighten rings?
10 replies to this topic
#1 joelin
joelin
  • Loc: Saratoga, CA
Posted 15 February 2020 - 04:41 AM
For rings like this: https://www.bhphotov...uide_scope.html
How tight can you tighten them if you're trying to grip a camera lens or a round CMOS camera body...
can I tighten them until my fingers can not tighten them anymore without damaging anything?
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 15 February 2020 - 06:11 AM
In theory, you could tighten them with your fingers until they start to dent the metal.  A "snug" fit is all that is needed.  if you don't want the threads to loosen, get some red Loctite threadlocker from your local Auto Parts store.   smile.gif
#3 jaraxx
jaraxx
Posted 15 February 2020 - 08:07 AM
Be careful.
"One never knows how much enough is before one knows how much too much is."
- Oscar Wilde ( I think)
#4 junomike
junomike
  • Loc: Ontario
Posted 15 February 2020 - 08:27 AM
I've always wondered about this as well.  If the rings (pinions?) are tight enough to hold the OTA + accessories at Zenith then how can they not "dig in" to the paint/finish of the OTA?
Otherwise It would slide down, no?
#5 mashirts
mashirts
  • Loc: Elgin, TX
Posted 15 February 2020 - 08:32 AM
The tips are Delrin so grip should be good.
Edited by mashirts, 15 February 2020 - 08:33 AM.
#6 Neptune
Neptune
  • Loc: Georgia
Posted 15 February 2020 - 08:35 AM
Seeing that the tips of the screws are more or less point sources. It does not take much in order to get enough friction to hold any item in place. I would think that finger tight would be more than enough. Proceed with caution.
  • joelin and LDW47 like this
#7 LDW47
LDW47
  • Loc: North Bay,Ontario,Canada
Posted 15 February 2020 - 09:17 AM
The rule of thumb for years used to be finger tight and then a 1/4 turn to finish, even on mechanical stuff unless you required torquing pressure which you don’t on astronomy equipment of course !
  • Neptune, Fernando134 and airbleeder like this
#8 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 16 February 2020 - 04:46 AM
Most of this stuff is aluminium alloy - soft. Finger-tight should suffice - beyond that you risk stripping the threads.
#9 Jon Isaacs
Posted 18 February 2020 - 11:53 AM
The standard advice:
Tighten until it fails,  then back off 1/2 turn.  :)
I would not finger tighten them until your fingers cannot tighten them anymore, that could cause damage and it's unnecessary.  I would play it by ear. Tighten them until the lens/camera seems secure and then test it to see if theres image shift.
#10 ryanr256
ryanr256
  • Loc: Southwest Ohio
Posted 18 February 2020 - 02:47 PM
-Bob
  • BFaucett likes this
#11 Hondo
Hondo
  • Loc: NB, Canada
Posted 18 February 2020 - 04:25 PM
In case you are not aware, red Loctite is permanent and will require heat to remove it.  Purple or blue can be removed without heat.
