Sharpstar 121SDQ Vs Sharpstar 140PH hard time deciding
6 replies to this topic
#1 MirkoV69
MirkoV69
Posted 15 February 2020 - 08:03 AM
Good morning all
I have decided to purchase my first "proper" setup for deep sky.
So far I used a Nikon 300 f2.8 photo lens as OTA but now I feel ready to move one step up
(nothing wrong with it but a little short focal lenght and I feel the need for proper focuser)
I am am havig a hard time deciding between Sharpstar 140PH  F6.5 triplet and Sharpstar 121 SDQ Quintuplet F5.6
The 121 incorporates a 2 elements flattner , the 140 needs to be flattened/reduced
budget wise the 121 is more expensive but as you add the reducer/flattner to the 140 the end up very close
I tend to lean onto the 140 as it offers the possibility to use different flattners: in case I am not happy with the sharpstar one I could possibly replace with 3rd party ones
At present I am using a Nikon D5200 (full spectrum modified) and plan to move to a cooled camera next year (possibly ASI 2600MC-PRO)
Would really appreciate opinions from people with more experience
thanks
best regards
Mirko
#2 junomike
junomike
  • Loc: Ontario
Posted 15 February 2020 - 08:24 AM
The 121 is lighter and has a larger Focuser, but overall either should be a nice option.
I would most likely go for the 121mm as It comes already set up out of the box.
Also, the 121mm has enough back-focus to use visually If wanted.
  • MirkoV69 likes this
#3 astrodom
astrodom
  • Loc: NY , USA
Posted 15 February 2020 - 10:45 AM
   It may also depend on the mount you are using.  I would guess that the 140 would weigh more by the time you add the flattener and camera, etc.   I have a 140mm refractor but its a little heavy and now that I am older, I find myself using my small refractor more often.  You can't go wrong with either scope in my opinon.
#4 tonyt
tonyt
  • Loc: Australia
Posted 15 February 2020 - 07:11 PM
Since you're moving up from a 300mm lens, I'd recommend the TS115/800 triplet which works well with the TS 0.79x 3" reducer - it's a cheap but very good scope and it's not heavy. After some experience with that scope you can add a significantly longer focal length scope.
#5 MirkoV69
MirkoV69
Posted 16 February 2020 - 04:57 AM
This is something I have not considered, but I will look into it
Mirko
#6 MirkoV69
MirkoV69
Posted 16 February 2020 - 04:59 AM
At the moment I have a AZ EQ6 , it is rated at 20 KG, the complete setup would be around 13 KG .... I think should be on the safe side
thanks
Mirko
Edited by MirkoV69, 16 February 2020 - 05:09 AM.
#7 Michaeljhogan
Michaeljhogan
Posted 16 February 2020 - 12:51 PM
Good morning all
thanks
best regards
Mirko
As much as these two Apo scopes from Sharpstar are the best Chinese Apos they are beautiful i would love the Sharpstar 140PH its way better than any
of the other TS-Optics PHOTOLINE 152 mm f/8 Triplet or the APM Doublet SD Apo 140 f/7 FPL53 or APM Doublet ED Apo 152 mm f/7.9.
I could never give 4.300,00 Euro for the Sharpstar 121 SDQ when the Takahashi TSA-120FT is only 400 more i would go for the 5.5 inch Sharpstar 140PH.
Edited by Michaeljhogan, 16 February 2020 - 12:52 PM.
