2 inch straight swap focuser for a Vixen A100M?
12 replies to this topic
#1 25585
25585
Posted 16 February 2020 - 02:48 PM
Any straight swap 2 inch focusers for a Vixen A100M made? Same tube size & holes alignment for simplicity.
The OE is 1.25" fit only.
#2 SteveG
SteveG
  • Loc: Seattle, WA
Posted 16 February 2020 - 04:30 PM
Is this the A105m?
Remove the focuser and measure the inside tube diameter. If it’s 96.6 mm, you’re in luck:
https://agenaastro.c...speed-96mm.html
  • 25585 likes this
#3 SeattleScott
SeattleScott
Posted 17 February 2020 - 04:19 PM
The A105 has a 2”. I think he is referring to the older 102 version which was 1.25”.
Interestingly, having had one of the older ones too, I noticed the draw tube is about 38mm wide. I thought about trying to find a thread on adapter so that it would take a 2” diagonal. Might vignette the widest 2” eyepieces but should work with a 31T5. But I didn’t get around to trying this so just theoretical.
Scott
  • 25585 likes this
#4 LDW47
LDW47
  • Loc: North Bay,Ontario,Canada
Posted 17 February 2020 - 04:33 PM
I would say you will easily get a 2” GSO straight swap from Agena Astro, go to their site its pretty easy my 3 took about 20 min. each to change ! And they are around $150 US for excellent quality !  Clear Skies !
  • 25585 likes this
#5 SteveG
SteveG
  • Loc: Seattle, WA
Posted 17 February 2020 - 05:29 PM
Provided he first confirms his tube ID is 96.6 mm.
  • Jon Isaacs likes this
#6 LDW47
LDW47
Posted 17 February 2020 - 05:31 PM
Correct ! That goes without saying, thats why I didn’t say it, lol !  Clear Skies !   PS:  If you read all the literature on their site pertaining to changing focusers they stress very clearly to make sure you measure the opening, the tube diameter.
Edited by LDW47, 17 February 2020 - 05:33 PM.
#7 Jon Isaacs
Posted 17 February 2020 - 05:33 PM
:waytogo:
And that it uses three screws to attach the focuser to the tube..
#8 Jon Isaacs
Posted 17 February 2020 - 05:36 PM
Nonetheless, it needs to be said and it needs to be said that the focuser needs to attach with three screws..
  • LDW47 likes this
#9 25585
25585
Posted 17 February 2020 - 05:54 PM
It is an A102M of the older tube style. The focuser is fastened with 3 screws, ED style.
Edited by 25585, 17 February 2020 - 05:55 PM.
  • eros312 and LDW47 like this
#10 LDW47
LDW47
Posted 17 February 2020 - 05:58 PM
The three I have are all 3 screwed and they lined up perfectly ! Three screws are my limited experience !  Clear Skies !
  • 25585 likes this
#11 25585
25585
Posted 17 February 2020 - 06:24 PM
  • LDW47 likes this
#12 Jon Isaacs
Posted 17 February 2020 - 09:31 PM
You've owned three Vixen A102M's?
#13 LDW47
LDW47
Posted 17 February 2020 - 09:34 PM
You can think that if you want and I should be so lucky but unfortunately I am talking the focusers and my three unrelated scopes, lol !
Edited by LDW47, 17 February 2020 - 09:35 PM.
