At60ed + X = solar Ha, help solve for X
1 reply to this topic
#1 swsantos
swsantos
  • Loc: Rhode Island
Posted 17 February 2020 - 01:06 AM
...And X does not equal Daystar Quark.
Already have  Lunt 50mm with the LS50c double stack. Can an AT60ed be made into a solar Ha at least as good if not better? Perhaps using my existing LS50c with an adapter and a blocking filter?
Anyone do something like this and how does it compare to a dedicated Ha only telescope?
#2 MalVeauX
MalVeauX
  • Loc: Florida
Posted 17 February 2020 - 08:31 AM
Heya,
Two front mounted etalons will ideally be better than an internal version one. You can get an adapter to mount the two 50mm etalons onto a specific scope and just add a blocking filter diagonal and you're set. The 50mm aperture etalon will stop your 60mm/F6 scope down to F7.2 which is nearly the same as the original configuration by Lunt. And you could go longer with a different scope. The adapter you would need ideally needs to thread onto the retainer cell of your OTA's objective or the len's cell itself if its threaded (some are). I would not use an adapter that just clamps onto the front of the objective or dew shield; the etalons are heavy.
Very best,
