Firstscope 80EQ focuser replacement?
18 replies to this topic
#1 toucansam
toucansam
Posted 17 February 2020 - 03:56 PM
Is it possible to upgrade/replace the focuser on the Celestron Firstscope 80EQ?
Thank you.
#2 vtornado
vtornado
  • Loc: Northern Illinois
Posted 17 February 2020 - 04:12 PM
I think scope stuff has some drop in replacement focusers.
The price is more than the scope.
What don't you like about the focuser?
#3 toucansam
toucansam
Posted 17 February 2020 - 04:18 PM
I would love to try a dual-speed on it.
#4 LDW47
LDW47
  • Loc: North Bay,Ontario,Canada
Posted 17 February 2020 - 04:37 PM
If you are talking the FirstScope 80mm from the 80’s - early 90’s, I changed mine with a well built GSO Crayford from Agena Astro in about 20 min ! All for about $150 or less !  Clear Skies !
Edited by LDW47, 17 February 2020 - 04:38 PM.
  • vtornado likes this
#5 vtornado
vtornado
Posted 17 February 2020 - 04:39 PM
I understand …
I have a single speed 2 inch focuser from scope stuff on my Celestron First scope.
I wish it was 2 speed, but I got my focuser for a good price from a member here.
A poor man's dual speed is replacing a focuser wheel(s) with a larger diameter wheel.
In the days of yore, the focuser wheel was held on by a screw.  Easily removed, and you can
try a jar lid or something similar.  Some later models have the focuser wheel glued or pressed on.
Much harder to remove the wheel.
BTW my scope is an 80 f/5, LDW is the 80 f/11, I think they are both referred to as first scopes.
I think they take the same sized focuser???
Edited by vtornado, 17 February 2020 - 04:43 PM.
#6 LDW47
LDW47
Posted 17 February 2020 - 04:40 PM
With that scope you really don’t need a two speed but they are only about $25 more if I remember correctly !  Clear Skies !
#7 Jond105
Jond105
  • Loc: Detroit
Posted 17 February 2020 - 05:02 PM
https://luntsolarsys...cuser-3-travel/
just ordered one of these myself from Lunt. It’s the best price and a drop in replacement.
#8 Jon Isaacs
Posted 17 February 2020 - 05:03 PM
Thank you.
As others have said, it's possible but it will cost over $100.  You can also just clean and adjust the focuser and that can be a significant improvement.
There are several versions of the Firstscope 80EQ. Most are F/11 but there's an older version that's F/5. The OTA is model 21072.
Which version do you have?
#9 Jond105
Jond105
  • Loc: Detroit
Posted 17 February 2020 - 05:06 PM
The one from Lunt with shipping was $86 shipped. Well worth it if you go that route.
  • SteveG likes this
#10 LDW47
LDW47
Posted 17 February 2020 - 05:14 PM
Thats for a 2” Crayford focuser ? That is a steal !  Clear Skies !
  • Jond105 likes this
#11 Jon Isaacs
Posted 17 February 2020 - 05:40 PM
The Lunt focuser does not come with a 2 inch to 1.25 inch adapter so that adds about $25.  If one is buying a 2 inch diagonal to go with the Lunt 2 inch Focuser, then the adapter is not needed.
#12 toucansam
toucansam
Posted 17 February 2020 - 06:01 PM
Thanks to all.  Mine is model 21072.
I bought the Lunt.  I have a 2" adapter and diagonal for another scope that I can use with the 80EQ.
  • Jon Isaacs, eros312 and Jond105 like this
#13 Jond105
Jond105
  • Loc: Detroit
Posted 17 February 2020 - 06:20 PM
Like Jon I had one fo those myself for a while.
  • eros312 likes this
#14 toucansam
toucansam
Posted 17 February 2020 - 06:32 PM
I've got a number of spotting scopes, and between terrestrial and astro use, I've really grown to love small, light, wide field refractors.  The Celestron, combined with an AZ-GTI, is the simplest grab-and-go setup I could muster, and setup is a breeze.  Plus it works great at dusk, keeping me and the kids from getting bored while we wait for the sky go grow dark.
Thanks again to all.  Now I'm looking forward to trying some 2" EPs in the scope.
  • Jon Isaacs and BFaucett like this
#15 Jon Isaacs
Posted 17 February 2020 - 09:12 PM
Excellent..
Here's a question for you and Jon D.:
I've had three of these. My current one has a metal thread on dew shield and a metal objective cell that threads onto the tube.
Do yours have the metal dew shield and objective cell?
#16 toucansam
toucansam
Posted 18 February 2020 - 01:19 AM
There are essentially no metal parts on mine at all, save for the focuser body and tube, which seems to be a combination of aluminum and some sort of pot metal.
What kind of ring clamp is that on yours?
  • Jon Isaacs likes this
#17 Jond105
Jond105
  • Loc: Detroit
Posted 18 February 2020 - 05:11 AM
Excellent..
No mine was the plastic lens cell with the dew shield that just slipped over.
#18 Jon Isaacs
Posted 18 February 2020 - 09:33 AM
Thanks Jon and toucansam:
I've owned a number of 80mm F/5s and except for this one, they've all had plastic lens cells and slip on dew shields.  I'm keeping this one.
#19 Jond105
Jond105
  • Loc: Detroit
Posted 19 February 2020 - 07:22 PM
So I just my dual speed focuser in from Lunt(GSO), had to rotate it but other than that, I like it better than the Synta standard dual speed focuser. Held my ES82 30mm nicely.
